What's on the Bench 2024
Another base for photographing models on:
[ATTACH]501185[/ATTACH]
This is one of the vacuum-formed dioramas by Heller, that I just glued to a piece of MDF (25 by 36 cm), and am now painting a colour called “butter pecan” with craft paint from FolkArt. I first sprayed a grey primer from an aerosol over it yesterday, because when I tried applying the paint directly on the bare, white plastic, that colour came through far too much, as the paint doesn’t “grip” well. Adding a coat of primer helped a lot, though I’ll probably still need to go over it in a few places to cover the primer better.Comment
Until the next GB i have a pile of parts from a rather large RC Scania!
Just ripped it down and going to re-route the wireing. There were just to many wires in to small a space!Comment
Alongside the Revell Raiden ive been doing a couple of bf109s , a Tamiya e-7trop and an AZ f-2 . I didnt bother with build logs as there wasnt much to see , and its not like we havent seen a 109 built before ! That said - I’m thinking of doing a side by side build comparison with the Tamiya and Airfix 109E s just to compare the different approaches to the kits .Comment
This is what I managed to make at the show yesterday and today:
[ATTACH=CONFIG]n[/ATTACH]
Not that I spent the majority of my time working on this, but look at the amount of putty I had to use on these parts … It probably took about the same amount of time filling, filing and sanding, as it took to clean up the parts and glue them together.Comment
