Will try that as 10 ton wrecker has been here the longest.
What's on the Bench 2024
Working on a Dragon Early-version M48A3 and the Hobby Fan infantry figure group... I went without the later improved cupola vision port ring and no search Iight either. Will be adding some stowage, mostly spare assorted ammo and fuel cans.I have the later version in my stash so will probably build that one in the near future. Hope you all like.Comment
Update on Revell 1/144 Saturn V build.
It's fine to post a picture or two in here, but try to keep it to just one of two... please, thank you, cherry on top and all that.Comment
My desk right now...
Build desk: Loads of bits of wire. I will try update the build thread. Don't hold your breath lol
Paint desk: Loads of bit of Landing craft. No build thread... SorryComment
If you would like me to pick historical accuracy nits, then if it doesn’t have the vision riser ring, it should probably also have the older type of headlights, under a round guard instead of the flattened one you’ve got here, as well as the mudguards with the front stays on the angled part … The square tail light guards and the bars around the exhaust grill are also later features that probably means the tank would have the vision ring. I can’t make out in the photos if the commander’s hatch (in the cupola) is the more bulged type for extra headroom, but that also goes with the vision blocks. Cupolas without it had a hatch with a rounder profile.
However, doing it the other way around (older mudguards, lights etc.) with a later cupola with riser ring, is definitely possible.
I also get the impression that the USMC in Vietnam (your figures are Marines) only had the earlier type of M48, some fitted with the later type of cupola, though.
RichComment
didn't have the interest or enthusiasm (mojo I guess) in dealing with changing any details , just wanted an OOB build. But, once I saw in a photo what you described, Yes I see what you mean. I know I can scratch the lighting frames easily enough, but the front light lens themselves look a no-go, for me this moment anyway.
I was ecstatic to then find out that the correct front & rear lighting is actually provided in that second kit I still have on hand. So... Whew !! It seems that all I have to do is build up that lower hull to mate with this turret. As for the bulge-style cupola, well I just don't know. This one seems to have a bit of a bulge built in, I guess. Anyway, once I see that feature in a pic then maybe I'll feel it's important enough to worry over.
FWIW, I have just ordered a couple of Patton titles that each are good photo references.
I wonder why the factory went to the trouble to provide different lighting styles to be used on Marine vs. Army tanks anyway...?
Anyway...THANKS Jakko !Comment
In the end, though, it’s your model, so feel free ignore my comments if you wantComment
The non-bulged version had vision blocks in it, the bulged version didn’t, I remembered after my previous post.
They didn’t. The tanks with the rounded headlight guards and individual lights are the “Mod. A” conversions, those with the flattened guards and paired lights are the later, improved “Mod. B” (there were no new-built M48A3s, all were converted from older tanks). It looks like the USMC in Vietnam only got Mod. As, while the US Army had both, and I think the ARVN probably only had the Mod. B (but I may be mistaken, as I didn’t actually check before writing this).
