The room has come on in leaps and bounds...
You may be able to link your tv to the tablet if you have an HDMI outlet, if you do then connect the cable to them both, into settings/display and scroll down and you should find that you can share across both of them. I have that set up from my laptop to the spare tv.
I see you have one of those helecopters sitting on the top shelf, are you like me, learning to crash in different ways...
Hole for the hose, put a pipe cage over it, it may not stop them but it will deter them, because they will not know what is on the other end and why do you need a cage??? a sign 'Snakes crawling loose" might help....
