Pledge Polish
  • Andy T
    • Apr 2021
    • 3239
    #16
    These are the ones I have. Definitely water based, so maybe you are thinking of something else Tim.
      • 18901
      My bad, I use this one….
      • adt70hk
        • Sep 2019
        • 10406
        #18
        Originally posted by Andy T
        [ATTACH=CONFIG]n1221862[/ATTACH]
        Andy
        How do you find it? Is is reasonably matt? Have you tried it through an AB? The Vallejo Resin varnish I use is nearly three times the price per ml?
        Thanks.
        • Andy T
          • Apr 2021
          • 3239
          #19
          I have to admit I haven't used it for a long while Andrew. The bottle is nearly empty and I discovered AK matt varnish which I really like for both brush & airbrush.
          I seem to remember it was quite matt though, and went through the airbrush okay with a little water to thin it. If you bumped up the pressure with a larger needle I'm sure it would spray neat.
          • adt70hk
            • Sep 2019
            • 10406
            #20
            Thanks Andy!
            • Mickc1440
              • 4775
              #21
              What’s your go to clear coat Andy?
              • Andy T
                • Apr 2021
                • 3239
                #22
                For gloss it's Mr Color GX-100 lacquer, but the ones I use most are the VMS HD acrylic varnishes. I use the satin a lot, and once I finish my bottle of AK matt I'll probably replace it with the VMS.
                • wotan
                  • May 2018
                  • 1150
                  #23
                  Mick
                  I guess this is not much help to you, since I am a part of a "foreign field", but this is what I use on my figures.
                  • Scratchbuilder
                    • Jul 2022
                    • 2689
                    #24
                    Hello Mick,
                    Pledge on Azon dries clear. It used to be Johnsons Kleer
                    Pledge floor gloss currently unavailable.
                    • rickoshea52
                      • Dec 2011
                      • 4076
                      • Rick
                      #25
                      Originally posted by wotan
                      Mick
                      [ATTACH=CONFIG]n1221982[/ATTACH]
                      Where do you get your Pledge polish from John - Canadian Tire or at a regular supermarket?
                        • 18901
                        Hello Mick,
                        This one Mike?
                        • wotan
                          • May 2018
                          • 1150
                          #27
                          Rick
                          To be honest it was a while ago but I think it was Canadian tire.
