How do you deal with chromed parts? I’ve got several on my current build which is ok but they still have mould lines to be removed which obviously removes the coating. These parts also require detail painting too, wouldn’t it just be simpler not to provide them?
Chromed parts
Great question indeed! I've had chrome parts before and I've been baffled about how to deal with them because the seam lines are so obvious but if you scrape it off the part will never look the same and some of the parts are almost impossible to scrape it all off. So I'll be watching this carefully to see what others do with it.
I did try to paint over the scraped line but you can never match the chrome look. -
To remove chrome, I use either Domestos bleach or Mr Muscle Oven Cleaner (needs plenty of ventilation when using). Others swear by Brake Fluid or Dettol.
Here are the chrome parts of my Ford Torino after 15 minutes in a ziplock bag containing Mr Muscle Oven Cleaner:
DaveDaveCov - Founder of The Airfix Tribute Forum 2006Comment
Plus one on domestos. I too strip them, clean them up, prime in gloss black, and paint. It looks better than the plastic chrome to me.Comment
When I stripped that Torino chrome, I did a comparison of Domestos with the Mr Muscle shown above. The Domestos took 18 hours!
Use whatever bleach you have to get the chrome off.........tidy up the parting lines etc.......prime......then respray chrome.....humbrol do a nice rattle can of chromePer Ardua
We'll ride the spiral to the end and may just go where no ones beenComment
I would endorse bleach. Even if you could attach a chromed part, which needed no clean up, neatly, in my opinion it never looks right. Too shiny and the chrome coating softens detail. Far better to follow the advice given and strip and repaint.Comment
I use cheap drain cleaner. Tamiya chrome is the hardest one. There is a form of clearcoat on the "face side" that is very resilient. Often one side you can see the chrome vanish before you. the other side takes all day. Or night. Or both.Comment
It seems that what works for one manufacturer's chrome doesn't work for another's. I have also found that some manufacturers have changed their chrome formula over the years, one example being Heller.
I made two Heller Citroen 15 CV kits which had been produced a few years apart. The earlier kit was stripped of chrome in less than 15 minutes using Domestos. The later kit's chrome parts had to be soaked in Domestos for more than two days before the chrome was finally removed. Nowadays, I test small pieces of chrome sprue first to find the best removal treatment before taking the "plunge" with the rest.
