Clearing a glue bottle "needle".
  • JayCee
    • Aug 2019
    • 1132
    I recently purchased a bottle of Revell Contacta Professional. On going to use it I found that the needle had been slightly bent in transit. This is no problem but the needle appears to have been leaking and is blocked. How can I clear this blockage ?. I believe I have read somewhere of using a flame. Usually use TET but it is proving useless on this kit. Any ideas gratefully accepted.
    John.
    • 18901
    I usually poke a suitably sized wire down mine. It takes seconds……
    • Andy T
      • Apr 2021
      • 3239
      Poke something down it as Tim suggests, but a fag lighter or candle flame works well too.
      • Gern
        • 9212
        ... but take the needle out of the container first! :smiling3:
        • JayCee
          • Aug 2019
          • 1132
          Thanks guys.
          John.
          • PaulTRose
            • Jun 2013
            • 6460
            • Tattooine
            Use pliers to pull needle out of bottle.....hold over a flame fir a few secs....it will go 'pop'
            Per Ardua
            • Miko
              • Feb 2024
              • 582
              A bristle from a wire brush is what I use, but holding it over a flame does work to
              Miko (Revell Contacta is the greatest asset to scale modelling since. . . )
              • Si Benson
                • 3572
                I like the glue but hated the dispenser so put mine into an empty Tamiya extra thin jar…..I can spread it neatly and it never blocks
                • Andy T
                  • Apr 2021
                  • 3239
                  Great idea. I rarely use it as I seem to get it everywhere!
                  • JayCee
                    • Aug 2019
                    • 1132
                    Thank you all for you assistance. A few seconds over a flame and there was the "pop" as mentioned by Paul. Now to try it on this weird Italeri plastic !
                    John.
                    • JR
                      • May 2015
                      • 18273
                      Yes prefer the flame method !
                      • adt70hk
                        • Sep 2019
                        • 10406
                        Boiling water in a shallow dish/saucer....
                        • BattleshipBob
                          • 6792
                          • Bob
                          • Cardiff
                          I have recently started using this myself. when I have finished I lean the bottle against something making sure the tip is pointing at a angle upwards. I find this allows the remaining glue in the tip to run back into the bottle. Yet to have a blocked tip?
                          • zuludog
                            • Mar 2015
                            • 239
                            I've tried those glue dispensers, but as we've all found out, they always block up, so I've stopped buying them
                            And I've given up trying to unblock them - I just make a hole in the hard plastic, and pour it all into a bottle of liquid glue, it's the same sort of stuff.
                            • Miko
                              • Feb 2024
                              • 582
                              When I'm done with using Revell Contacta I point it upwards and squeeze, when I hear air coming out I know it's clear and replace the long blue cap
