Masking cockpit techniques
    • 15784
    Originally posted by rtfoe
    The new stretchable Tamiya tape should make this easier although I've never tried it
    I've used it and it's ok. A bit thick and the wider the tape the less easily it bends. Use a narrow strip along the curve and fill in with ordinary tape is the best method I've found.
    • Andy T
      • Apr 2021
      • 3239
      #17
      Originally posted by Valeron
      That's kind of what I do Andy. But when I've rubbed it down well, I cut it in situ on the canopy. And sometimes slip and scratch the canopy.
      Do you remove it once you have the impression and cut it on a cutting mat, then apply the cut piece to the cockpit?
      I cut it in situ.
      It does take a steady hand I'd agree, but then I always try to be careful with a super sharp knife in my hand :surprised:
      • Flip
        • Jul 2022
        • 259
        • John
        • Speyside
        #18
        Have you tried Bare Metal Foil?
        I used it on this Spitfire canopy:
        Just keep a real sharp blade in your knife and clean the adhesive off with IPA.
        • Del640
          • May 2020
          • 1151
          #19
          I also use metal foil...can't go wrong with it really.
