A Different Direction..............
Never thought of this. The moulding company in my head is Renedra. They make thier own stuff, but also act as a moulding company for most other gaming figure UK companies. However, not all of them have the lines…..I suppose the companies that sub out the manufacturing make thier own moulds?Comment
It has 20% infill - that means that there is a sort of honeycomb support structure under the skin. It means that the print is lighter, takes less time to print & uses less filament. The infill geometry is generated by the slicer programme, and you can vary the infill all the way up to solid ( 100% ). Just another setting you can change!!
DaveComment
For the second time I managed to give myself an electric shock - so I decided it was time to print out the power supply cover from Thingiverse by Area51. - This incorporates a space for a switched plug socket
Bit doubtful about this one, it's going to take 5hrs+ to print. The first layers have gone down well & it's sticking - just a matter of going away & leaving it to do its' stuff.
DaveComment
[ATTACH=CONFIG]n1193382[/ATTACH]
DaveComment
Well, it actually took 61/2 hours to print and this was in draft mode
Drafting is for functionality, not aesthetics - not sure why the odd marks on the left in the last picture. That was facing away from me on the build plate, and I only saw it when I popped it off the plate - It doesn't seems to affect the mechanics of the thing! This guard will prevent my fingers from finding the tingly bits, and add a switched plug connection. I'm getting more confidence in the reliability of this now, but not enough to have it running overnight ( yet! )
DaveComment
[ATTACH=CONFIG]n1193409[/ATTACH][ATTACH=CONFIG]n1193410[/ATTACH][ATTACH=CONFIG]n1193411[/ATTACH]
DaveComment
I'll put up some pictures of the fitted cover tomorrow - then I think that is it, for this thread, it's been about the trials & tribulations of building the 3D printer, setting it up, and learning the basics of how to begin tweaking the slicer programme for better results.
So far I've only printed models created by others, later this week I hope to start printing some of my own. Simple at first, but hopefully getting more adventurous! I'll be starting a new thread, which will be about creating something actually relevant to modelmaking!
DaveComment
