I found a pack of diorama bases on Thingiverse by 'somnus' I printed this out at the highest resolution............
It's about 75mm diameter - unfortunately something went amiss with the base & it's pretty rough underneath. I think another round of Z-axis & build plate levelling will be needed. One thing that I am pleased about is the magnetic build plate - I've had very few problems with the prints not sticking & they can be easily removed. Not that this has any model, making connection, I've a mind to try something in what is called 'spiralise' mode. This is a print which consists of a single continuos layer in a spiral - the examples I've seen are generally vases etc.
For quite large prints, they don't take much time, as the volume extruded is small.................. It should be a test of the printer - a tall print should prove the stability of the printer frame.
