FDM PLA 3D printing - with a model making inclination
    Finally ran out of blue PLA - onto grey
    1/72 Churchill AVRE with fascune rack
    1/72 Sherman BARV
    Both need a clean up , but lookng good & ready for primer
      Whilst most models come in complete parts, some come as 'flat packs'
      1/72 Churchill ARK
        With a minimum of clean up & a few drops of CA.....................
        ps - I'm printing off 2 post-war tanks - Centurion AVRE & Centurion ARV
          In my search for the unusual - both at 1/72.......................
          Churchill Mk.I
          Alecto - only a 1/76 model appears in Scalemates, so not very common. Info is a bit patchy on this machine - ' several made ', ' limited number produced ' It's small, the hull is only 60mm long!
            Universal Carrier - Wasp II in 1/72
ID:	1223408Click image for larger version
            I think I've reached the smallest I can achieve with FDM
            .......................and yes, I still have failures - this is the 3rd and final attempt to print this
            1/72 Rolls Royce armoued car 1914 - not possible with my FDM printer - the front mudguards are just too flimsy.
              Some more unusual vehicles, all in 1/72
              Churchill 3" Gun Carrier
              Centurion AVRE
              Centurion ARV
              All modern tanks seem to have really small fittings, which are really difficult to print by FDM - and as soon as I see 'slat armour' - forget it ( in 1/72 at least )
                I printed a 1/72 A7V -
                I'd had enough of the black PLA - it's gone back into storage with its' companion, the silica gel pouch
                and back to a neutral grey & how much better it looks!
                CA1 Schneider in 1/72 - The St Chamond is printng now
                  • 18903
                  Your painting queue must be stretching around the block by now Dave Interesting stuff though.
                    I was thinking of getting a big bucket of primer & dipping them!
                      a 1/35 Culin Hedgerow cutter for a Sherman
                      - probably a bit too neat! These things were knocked together in Field Workshops from German beach defences ( or so I read ).
                      A weird alternative fir the Sherman, instead of the Calliope - the Whizbang - actually saw ( limited ) combat
ID:	1224266 That's going to take a bit of printing in 1/35
                        [ATTACH=CONFIG]n1224265[/ATTACH]
                        [ATTACH=CONFIG]n1224266[/ATTACH] That's going to take a bit of printing in 1/35
                        I was right - took 12 hours to print - the clean up seems to be impossible! I'll probably have to cut the thing in two to do a succesful print.......................
                          It'll probaby print as a resin in one piece, but with FDM the space between the turret top & the launcher is just too narrow to allow clean up - I just had to try! Ironically splitting it into two has cut the overall print time down to ten hours, there's less support structure needed
                            I printed the whizbang turret in two halves & ca'd them together
Name:	whizbang front.jpg
ID:	1224344Click image for larger version
ID:	1224345 A little filler needed, here and there
                            Another Sheman turret oddball - again in 1/35 - the Sherman CDL
ID:	1224343 What I need now is a M4A1, as both these turrets seem to have been mounted on cast hull versions - I do have an Italeri model in the stash that could be a suitable donor
                              I have only one Italeri M4A1. so I decided to print one - the hull wasn't too much problem, but the weak point is the tracks - even if they were resin printed, they wouldn't be very good
                              Still, the hull fitted with the CDL turret
                              ......................and with the whizbang turret
ID:	1225002Click image for larger version
                              in 1/35.............................
                              I also printed a 1/72 Beaverette, the original converted car model..............
                              On the edge of what's useable!
