Lithophanes..................
    According to Wikipedia "A lithophane is a thin plaque of translucent material, normally porcelain], which has been moulded to varying thickness, such that when lit from behind the different thicknesses show as different shades, forming an image. Only when lit from behind does the image display properly. They were invented in the 19th century and became very popular, typically for lampshades, nightlights, or to be hung on windows. They could also be given stands, to be placed in front of a light source"
    I'd seen some of these on Thingiverse, so I decided I'd see if I could FDM print one The first attempt failed, it came off the build plate, they're thin & don't have much contact area, so I tweaked various settings, and
    Four hours of printing,thinking that any moment, it's going to come adrift!
    This is what it looks like under normal light................
    And against my living room light
    And against my emergency LED lantern
    Emilia Clarke from Game of Thrones.
    I'm trying to create my own, using a free program from the internet, not quite as simple as I thought - my first attempt was too thin & had holes in it! - another attempt being made.
    I first saw a lithophane in the bottom of a George V Coronation Teacup from 1910. It was one of several that my maternal grandmother had - all chipped & some missing their handles. On her death, one in pretty good condition passed to my mother. Sadly my mother developed dementia, and she was obsessed with 'tidying' things up. A couple of Clarice Cliff ceramics - and the teacups were disposed of - no idea where......................... The saddest thing we found was that all the family photo albums had been tidied. The albums, with carefully annotated pictures ( in white ink ) had all the pictures removed & put in a tin box the albums discarded. We have all the family photos, going back to the 1890's - several hundred - but no idea of dates, or who any of the people are. All those generations have passed & now they're just nameless
    • 15655
    That lithophane is very clever and a successful print. I've not heard of it before so I've learned something new.
    • JR
      • May 2015
      • 18273
      That part about the items thrown away rings true, my late mother in law who also had dementia.
      She would throw any thing away , hide things .
      Photos ripped in half . All very sad.
      Think that Lithophane is brilliant, like Jim I'd never heard of it either. Well done .
        This was the first lithophane I saw......................
Name:	george v lithophane cup.jpg
Name:	george image.jpg
        I don't remember any saucers! ( pics off the 'net )
          Printer finished this late last night
          HMS Goliath 1898.
          Selecting a picture is important, it must have good contrast, and not too much fussy detail. You can use any photo you like, but the LithoPhane Maker only uses .png files! What you should not do is scale the 'phane down to fit on the build plate - this scales everything down, and the background becomes too thin to print correctly, and you get holes!
          I won't be doing any more Lithophanes. it was just a diversion to see what was doable!
            • 18890
            [ATTACH=CONFIG]n1202239[/ATTACH]
            HMS Goliath 1898.
            Fascinating stuff. Never heard of them before.
              This was the original photo
              The lithopane I printed was 100 X 50mm - that took around 7 hours to print - any larger - it's the square of the area ( ie if you double the dimensions, then it will take four times as long! ) Not exactly a speedy process - although it should be possible to create a silicone mould, and using casting resin to make duplicates! ( Your mind sometimes goes along these routes! )
              • adt70hk
                • Sep 2019
                • 10400
                That's come out very well Dave, very effective, shame about the family photos though.
                ATB
                  ATB
                  Andrew,
                  the family pictures were only part of the story - all my photographs taken during my time in the Merchant Navy were disposed of. A bitter blow, but my own fault, assuming they'd be safe in the loft at the family home..........................:crying:
