After my Monoprice Mini died ( burnt out chip on mainboard ),I looked around for a replacement I just happened to chance on an Ebay auction listing for this
" new " no bids on it at £30 + 3.93 p & p - less than an hour to go! I knew the name Kingroon, but nothing about this printer. I hurriedly looked at all the reviews I could, downloaded the manual, there didn't seem to be any major red flags - so, I put in a bid & got it for the starting price!
It was delivered today - I was prepared to be disappointed, but it looks that the box has been opened for inspection, but nothing else. Never been assembled, all the screws, tools etc in their little ziplocs, the build plate has never been touched - all in all I was well pleased. I'll put it together tomorrow ( all of 6 screws to add & tighten ) and see if it works!
Specs are 180 x 180 x 180 magnetic heated build plate. 0.4mm nozzle, 1.75mm dia filament. Direct drive extruder, linear rails for the X & Y axes, normal wheels for the Z axis.
It has a small footprint ( heavy too! ), but that is really offset by a separate power brick, and an external filament holder - neither of which are critical - I have the SunLu printing a top mounted filament holder at the moment, and there is a base you can print to fit the PSU underneath the printer.
It has a tiny little touch screen, and it's manual levelling, it can't print exotic filaments ( temperature limits ). but I only use PLA, so thats not a problem, doesn't have wi-fi, filament run-out, uses a standard micro sd card. I downloaded a configuation for the KP3S for my PrusaSlicer ( that sets the build plate size, parameters etc in the programme ) , so hopefully this will be up & running tomorrow morning
