Here is a little "home made" recipe for papier mache, im sure most people just use watered down PVA but this saves the money!!!!
Boil 5 cups of water in a saucepan.
In a bowl mix 1/4 cup of flour (sieved) with 1 cup of cold water.
Wisk/mix untill a smooth consistancy is reached.
Add the mixture to the boiling water.
Gently boil, stirring constantly for two - three minutes untill thickened.
Allow to cool before using.
This will keep in an air-tight jar for about a week, it can seperate but you will just need to give it a shake every once in a while.
