Those of you who have used Plastic Putty will know that it can be cleaned up with a damp cloth, cotton bud or even a finger. They will also know that 'damp' is the right word - too wet and you can wipe the putty out of the joint you're trying to fill. If you usually make the cloth damp by putting it in between your lips, then you will also know how 'orrible it tastes!
Solution:
Take a fairly big piece of cloth and fold it so you have about four layers thick. Using a small dropper bottle, drop a little water on to the cloth so it soaks in. You can now take the cloth/cotton bud or whatever you are using to clean the kit and gently rub it over the damp spot on your cloth.
Voila! Instant damp - without the nasty taste!
Solution:
