Cutting round holes in thin wood
    I needed to make 11 port holes, 3/8" in diameter for the covered navigation bridge plating on the 1:24 scale submarine, in thin, soft, 1/16" basswood. I tested using a drive punch, and found that my larger, high-quality 1/2" leather drive punch could cut nice clean holes with one or two wacks from a lignum-vitae mallet. However, my cheap, utility tubular steel 3/8" punch would not penetrate, and after 6 wacks split the test piece! The edge was not good on it.
    I decided to try putting it into the drill press, to use as a tube-drill. First I spun it up and touched up the edge a bit with emery cloth, then made test cuts; I ran the press at medium speed. I found that a gentle press, lift, press, lift, press, lift routine will result in a very clean circular cut in three to five "taps." This shot was taken just after cutting the eleven ports:
    Tube-drills like this can be improvised for small numbers of holes, from brass hobby tubing.
    HTH, John
  • spanner570
    • 15383
    If I may John, and as a sort of follow on to your post, the following tip was shown to me whilst serving my time as a joiner, and could be of some use to members.....
    I am sure you know the trick John, but for those who don't.....
    When drilling holes of any diameter in timber or plywood, always firmly place a scrap piece of wood under the piece to be drilled. Then when you drill, go straight through your 'wanted' piece into the backing one.
    This way you will always get a clean exit hole on the underside of the top piece.
    I hope this will be of some use to someone!
    Thanks John,
    Ron
      Another point worth mentioning is that the cutting edge would benefit from being bevelled from the inner diameter of the brass tube out this gives the outer diameter a clean straight cutting edge. (if the bevel's on the outside then the inner edge of the hole will crush a little due to the bevelling of the edge (sometimes though this effect is desirable)
      You can use a fine round file to bevel the inner edge of the tube by putting the tube in a drill and holding the file at the required angle inside the tube untill you get the desired cutting edge.
      Just a tip i picked up from a saddlemaker.
