Rotary Tools for Modelling
  • slupanter
    • Jun 2010
    • 554
    Hi all, I need some guidance, I have a new Dremel and I would like to use it you cut and sand (remove details) during the build.
    What do others do and what rotary toolsets do you all recommend?
  • minitnkr
    Charter Rabble member
    • 7510
    • Dayton, OH USA
    Several arbors for cutting discs & sanding/polishing barrels. Specific disc designed for cutting plastics & carborundum discs for metal. PaulE
    • Ancientmariner
      • Feb 2018
      • 859
      You've probably sorted it by now but Lidl have some excellent Parkside sets that are quite cost effective for what you get.
      James
      • BattleshipBob
        • 6785
        • Bob
        • Cardiff
        I have the Parkside one, good value too
        • Peter Gillson
          • 2594
          Don't laugh. But here is a very chesp drill/polisher - designed and sold for polishing fingernails!
          what I like is that it is battery power,so I can use it in the lounge and not upset the rest of the family, the down side is that Dremel bits are a very tight fit, but on the whole not bad for under a fiver.
          Peter
          • Richard48
            • 1889
            • Richard
            • Clacton on Sea
            That looks a good altenative Peter.Dremel makes so much noise and mess when im forced to machine resin bits in our small flat.
            Rich
            • Bobby Conkers
              • Jan 2020
              • 529
              Peter
              [ATTACH alt="6A1DFCAE-3259-4445-812A-F746437CEFBB.jpeg"]404337[/ATTACH]
              My daughter is a nail art specialist and I can tell thee, nail tools are the best. Plastic is very close in behaviour to keratin at room temperature. All my sanding, filing, cutting tools are nail tools. Another advantage is that an identical pair of podiatry snips are about a fifth of the price compared to when they're called "model-maker's snips".
              • boatman
                • Nov 2018
                • 14450
                • christopher
                • NORFOLK UK
                OK MR Conkers each to his own if that what you like an they do a good job an when are we gonna see more of the cutty sark build that you was doin ?
                chris
                • JR
                  • May 2015
                  • 18273
                  Thanks for that Andrew, like a lot of tools if they say it's for a certain hobby the price skyrockets.I'll have a look at podiatry snips.
                  • Peter Gillson
                    • 2594
                    Nice to read that I'm not the only one to have discovered nail art tools.
                    Peter
                    • Bobby Conkers
                      • Jan 2020
                      • 529
                      Peter
                      We also have a litre bottle of solvent in the house which I use for paint thinning!
                      • Bobby Conkers
                        • Jan 2020
                        • 529
                        chris
                        I'm on it. Hopefully a dust and clean this weekend and we'll see where we are.
                        • boatman
                          • Nov 2018
                          • 14450
                          • christopher
                          • NORFOLK UK
                          OH Great thing mr Conkers lookin forward to seeing more of your cutty
                          chris
                          • yak face
                            • Jun 2009
                            • 13824
                            • Tony
                            Peter
                            Ive got the exact same thing peter , works brilliantly . I put the battery in the wrong way round so it goes clockwise and i can use my micro drill bits in it . Its so much better than dremel type motor tools , as most of them dont go slow enough not to melt the plastic . Even this though can make a mess if youre not careful. Like yourself and Andrew ( bobbyconkers) I use a lot of stuff thats meant for doing nails . All my wet and dry sanding sticks are nail files and cuticle nippers , push sticks, dotting pens , lining brushes , caviar balls and nail art gems all feature regularly on my bench ! Cheers tony
                            • Bobby Conkers
                              • Jan 2020
                              • 529
                              Oh yes, push sticks! Stirrers, dabbers, pokers, dibblers, clamp guards, liner uppers! My box of tricks is full of them.
                              I have a dotting pen with a head the size of a golf ball made of pure superglue as well!
