Actually not giving a tip just expecting some I hope. :smiling:
Dart Herald has raised panel lines. Such a lot going on at the joints of the fuselage & wings worst junkety I have ever seen. So lots of sanding.
Raised pane line are going to be disturbed. Do not want to remove raised & replace with carved out as the raised rivets will also be disturbed.
Any"brilliant" ideas. Only one I have is to remove a short length back to a junction & replace with recessed panel line. Hoping at 1/72 it will not be noticed.
I am not putting any great effects on the aircraft just as very light wash most of which I remove ie not accentuating the panel lines.
On 1/48 I think I would use a very thin rod but 1/72 hoping to much.
