Weathering pencils
  • dalej2014
    • Aug 2021
    • 507
    Weathering pencils
    A (slightly) cheaper alternative to the model weathering pencils are artists watercolour pencils. I like the Derwent ones personally. Good pigments and work well wet. You can also buy sets of metallic, ideal for weathering and so on. Of course, if you want the real thing, specifically designed and made for the job, check out the shop.
  • JR
    • May 2015
    • 18273
    Nice one Dale.
    You can make your own rust as well , placing metal screw in a jar and adding some water. Soon have a sludge that is the real thing. Just seal with a varnish.
    Fine soil and sand from swirling muddy water about in a pale / bucket and collecting the fine debris in the bottom. This I dry out, then MW to kill off any unwanted vegetation !
    • dalej2014
      • Aug 2021
      • 507
      Nice one Dale.
      Love this. Great tip. I'll definitely be trying it out. Thanks John :thumb2:
        • 18876
        Cheap pastels are good as well. Just grind them up on fine wet and dry……
        • dalej2014
          • Aug 2021
          • 507
          Agreed. I got some earth pastels from ebay for about £3 to grind for pigments.
