DIY Spray Glue
  • Bobby Conkers
    • Jan 2020
    • 529
    DIY Spray Glue
    Hi ladies and gents.
    Just a quick one - if I want to create a pumped PVA spray glue (I avoid aerosols), what mix of PVA and water would a chap use? Also, I presume a couple of drops of washing up liquid would be wise?
    TIA,
    Bobby
  • JR
    • May 2015
    • 18273
    Morning Andy !
    The mix needs to be thin enough to pass through the spray unit, so if you try a 50/ 50 mix in a small container and then see if it passes through ok .If it does then add a couple of drops of washing up liquid to a mix and put into the unit .
    I've found that a pipette of IPA on the area to be sprayed helps break down the surface tension and the spray mix will flow extremely well .
    Have a look at Luke Towan on UTube for list of videos on PVA mixes .
    • rtfoe
      • 9065
      50/50 for me as well.
        • 18876
        Same here, fifty fifty with a single drop of dish soap to act as a dispersant. However, be sure to rinse the spray nozzle through carefully afterwards. The glue will set in it and block it solid otherwise.
        • Bobby Conkers
          • Jan 2020
          • 529
          Thank you all. Yes, I figured I'd need to clean nozzle and tube after each use, and seal it up just in case. I'll check out that Glue Guru's videos. Thanks again!
          • Tworrs
            • Jan 2022
            • 1978
            • Garry
            • New Zealand
            Thanks John and Andy et al, that is really helpful information :smiling2:
            • Bobby Conkers
              • Jan 2020
              • 529
              Just as a quick addendum, I've found these mayonnaise bottles to he excellent for thinned PVA. They have a very useful nozzle which doesn't clog as, not to put too fine a point on it, they have an anus instead of a nozzle.
              [ATTACH]444901[/ATTACH][ATTACH]444902[/ATTACH]
              • prichrd1
                • 691
                Then you better make sure you wipe it clean as well !!!!!!!! :smiling: :tears-of-joy::tears-of-joy::tears-of-joy::dizzy:
                You know what Matron is like for hygiene on the ward!!
                She doesn't like a messy nozzle!!
                Paul.
                :smiling:
                • rtfoe
                  • 9065
                  I suggest wetwipes...easy on the anus. :tears-of-joy: ...but warm it first.
                  • Nicko
                    • Apr 2019
                    • 1394
                    • Nick
                    • East Anglia
                    I'd be more worried about ending up with glue on my chips! :rolling:
                    Nick
                    • Bobby Conkers
                      • Jan 2020
                      • 529
                      Nick
                      Yup, that would have caused me sleepless nights, so...
                      [ATTACH]444962[/ATTACH]
