Why do we Prime
  • BarryW
    • Jul 2011
    • 6007
    #31
    To be honest Barry, over 90% of what I build is armor and soft skins. I have only recently gotten into building aircraft in 1/32. With armor, I may spray a red oxide undercoat but that's only as a basis for chipping and damage to the topcoat and camo. I am a person who washes his hands every time before I work on a kit. Sometimes 10 times a day, when I take a break to eat, shop and the like. With armor, you can always fix any small flaws that arise very easily without priming and weathering/mud is one of your best friends.
    With my current Wingnut Wing's build, I may shoot a primer coat on the fuselage for the above stated reasons in this thread. The wings are one piece and I will paint those before applying the lozenge camo decals, but priming isn't necessary on them. When I get back to my 1/32 Arado 234 build, I think priming will be beneficial as it's a multi-media, short-run kit. Getting the wing root and fuselage joins smooth, by eye, won't be that easy. I'll have to wait and see though...
    Allen
    Yes, I see and it makes sense that armour is different to aircraft in this.
    I think that you might find some primer helpful for those aircraft. I look forward to seeing that completed Wingnut build posted, it could be very impressive with that lozenge camo. I assume the AR 234 is the mainly resin kit? Not into resin myself and you are right, multi-media does benefit from priming.
    • Allen Dewire
      • 4741
      • Allen
      • Bamberg
      #32
      Actually Barry, the Fly Arado 234 kit's fuselage (in 2 sections) and wings are plastic. The cockpit and radar observer's pit are resin, along with engine internals. The wing's fit together really good, but the fuselage sections will need a bit of filling as well as the wing to fuselage joins. It's to be expected from a short-run kit.
      I also hope the lozenge decals come out well and the rigging too!!!...
      Allen
      • David Lovell
        • 2186
        #33
        Oh well a simple question has turned into the usual Preachers v's Heathens ,I prime ,I prime because I want to not because my runner bean crop will fail as some of the Preachers would have me belive no it just gives me a nice solid background to work to ,if it helps others to see and correct faults in there work good im pleased but unless I've made a mighty bosh somewhere it can stay as it is I dont care I build for my own pleasure.
        So the answer is its down to personal preference what ever you choose the modeling police won't bang on your door it won't affect the world you live in and if you feel its affecting what your trying to achieve you'll know what to do ,its called the learning curve.
        • Mini Me
          • Jun 2018
          • 10711
          #34
          Right on Dave! :thumb2:
          • AlanG
            • 6296
            #35
            Didn't see any of that sort of divisive comments in this thread Dave. But each to their own
            • JR
              • May 2015
              • 18273
              #36
              Matron will be watching those of you who don't:surprised::sad: because it improves
              1. Adhesion
              2. Coverage
              3. Self-Leveling
              4. Durability, thats why.
              Try not priming some surfaces and you will find out what its used.
              Taxi please.
              Good Afternoon .
              • Waspie
                • Mar 2023
                • 3488
                • Doug
                • Fraggle Rock
                #37
                Taxi please.
                Good Afternoon .
                And that is exactly what I will be doing in the next few days. Never primed before so it will be a learning curve for me.
                Question regards seems after priming! How do you eradicate seem lines?
                • BarryW
                  • Jul 2011
                  • 6007
                  #38
                  The processes I adopt are as follows:
                  1/ Before priming. Sand the seams with sanding sponges or sticks, using various grades of sander, working down to the finest grades. That ensures you get no scratches. Check the seam by looking along it under a light. If the are imperfections, then use a fine filler, I usually use Mr Dissolved Putty as it has excellent self levelling properties so the solid material ‘sinks’ into even the tiniest imperfection, leave it to cure for a good few hours. Sand again, working down through the sanding grades. You might want to start this at a finer level than the first stage.
                  I do this on every subassembly, I might have several of these subassemblies to pull together before priming as the seams between subassemblies might also need treatment.
                  2/ After priming. Examine the model closely. Look for any glue or other flaws shown up by the primer, check the seams, as before, looking along the seam under a light. Make no mistake, no matter how carefully you looked before priming there will still be imperfections showing. What are called ‘ghost seams’ are common. The reason for that stage 1 is to get the ‘basic’ heavy lifting done before priming and reduce the effort after priming. Take it for granted that every seam will need treating.
                  You are likely to see points or areas that need more treatment. I tend to use small pieces of masking tape to mark these areas. I then use Mr Dissolved Putty on those areas followed by sanding again through the grades. Then reprime and check again, repeat if necessary.
                  After your final reprime, check the engraved detail and rescribe such as panel lines and rivets where is has been sanded away. Check YouTube for help on this, it can be tricky to do but is well worth the effort.
                  Note, it might be worth, on some models, to lay masking tape each side of a seam to limit the damage to the engraved detail and reduce the amount of rescribing you need to do.
                  Finally get a polishing sponge and run it all over the primed surface to ensure it is nice and smooth ready to take a base coat.
                  I hope that helps.
                  • Airborne01
                    • Mar 2021
                    • 3934
                    • Steve
                    • Essex
                    #39
                    Now I know why I have developed a preference for AFVs!
                      • 18876
                      I hope that helps.
                      Very sound advice Barry. Regarding rescribing seams lost during sanding, I’ve found it useful to rescribe the existing detail deeper as it gets eroded, and before it disappears. That way you are not rescribing completely from scratch.
                        • 15633
                        Now that's a good idea. A tip worth noting :thumb2:
                        • BarryW
                          • Jul 2011
                          • 6007
                          #42
                          A good tip.
                            Many acrylic paints will just about fall off if a primer isn’t used.
