Hi - can anyone advise me what to do with a door of an electronics bay? - Do I only have the option of open or closed or is it possible to hinge it? Or do I make it just tight enough that I can remove it - any advise would be great - thanks
Creating a hinged door advise
GuestTags: None
What scale are we talking here? Depeding on the size, you might be able to get a small drill bit, drill vertically through the hinges (which you might have to make yourself) the run some wire or mabye part of a paper clip through it. Keep in mind, i have never tried any of these ideas and the thought of the idea simply intrigued me. These were just the first things i thought of. Good luck.
Brian
