Hello all thought you might like this idea.
All you need is the following
A pack of Tamiya finnishing paper
Household all purpose glue
A handful of those wooden stirring sticks you with your coffee from a cafe or canteen.
What to do
Mark the back of the finnishing paper to the size of your stick either laying flat on it's side edge, if you do that then make it long enough to wrap around the end.
Then apply the glue and stick the paper to the stick and leave for 24hrs all the better if you have some pegs or small mini clamps to hold everything in place.
Use some tipex at the other end of the stick to mark a white background then with a fine tip marker pen mark the grade of paper.
You can if you wish cut the sticks down to a fine point so you can get into those hard to get to places on models or figures.
Hope it helps
Regards
David
What to do
Hope it helps
Regards
David
