How do you make a wash using enamel paints?
    I have been doing a lot of reading - both on this forum and on outside pages - and I do not quite grasp the concept of how to actually make a wash. I have Testors enamel paints with Testors Thinner. How would I go about making a wash? I love the detail that this brings out when all is said and done. Another thing, I do not have an airbrush, but is it still possible to do a pre-shade with standard brushes? I am lost with how to actually mix things to make washes, pre-shades, etc. I appreciate all your help! Thank you in advance.
  • stona
    • Jul 2008
    • 9889
    Very quickly and simply (I'm off to cook a goose!) there are two basic types of wash. You can make a "sludge" wash using acrylic paint. Dilute the paint to about spraying consistency, add a couple of drops of washing up liquid and apply (no need to be careful) to your panel lines,hatches,etc. Let it dry for a while and wipe of excess with a damp paper towel...voila!. Alternatively buy Phil's excellent ready made washes from Pro-modeller. He does a variety of shades and a bottle lasts a long time! As a general purpose wash grey is less stark than black.
    The alternative is an oil wash. I use artists oils for this. I bought a selection of colours (umbers,greys,black) years ago and have hardly started to use up what's in the tubes. You can get some quite small (21ml) tubes that will last forever. Make a very thin mixture of the paint in a suitable solvent. I use a turpentine substitute called "sansodeur". A mate uses lighter fluid! All this stuff is available from an art store. I then apply the wash to panel lines etc with a fine brush. It will wick along the lines by itself. If you are careful there is no clean up needed. This method gives you more control of the colour (is it oily or dirty?) and you can apply different shades in different areas.You can also make repeat applications in areas you want to emphasise.
    Whichever method you use be sure to protect your paint with at least a couple of coats of a clear varnish. Everyone's favourite is good old Johnsons "Klear".
    If you preshade with a brush you may not achieve the feathered edge to the shading and may end up with a jig saw effect. I'm not sure how you would control how much of the shading came through when brush coating your other colours,you might need to experiment! Post shading,by dry brushing lighter tones in the centre of the panels certainly works. There was an entirely brush painted jet on a French site recently (can't find link) which was stunning. It represented an aircraft based in the tropics (Chad) and the fading and weathering had to be seen to be believed.....proof positive that you don't NEED an airbrush.
    Right that's me off to put my pinny on!
    Merry Christmas to you and everyone else!
    Back soon.
      Thank you for the reply! I am highly considering ordering the washes from pro modeller. I was going to get the cockpit wash and I am still deciding on a wash for the outside of the aircraft. Any suggestions? Slowly but surely I will learn all this. I have ventured into a whole new world of scale model building. It's very rewarding, but intimidating at this point. Thank you for the advice you all share with me!
      • stona
        • Jul 2008
        • 9889
        I'd recommend the promodeller washes. They are easy to use and work very well. You can use more than one . As a general wash I use the darkish grey one which IIRC is called dark dirt. I can't get into the cupboard at the moment to check due to the bl++dy Xmas tree!
        • jspitza
          • Jul 2007
          • 586
          I use Turpanoid (or turpentine) and Raw Umber oil paint mixed together very lightly. Using a soft paintbrush, I stream it into the lines and allow it to flow. Wipe away the excess as needed and allow to dry overnight or at least 24 hours.
