1
Some plastic liquid glues come with a metal tube applicator ,and Im sure at some stage you have found that this becomes blocked.
What i do is to remove the tube ,find a metal staple ,straighten the staple with pliers and then put a 90 degree turn in the end of the staple. Now place that small piece of the staple into the tube applicator ,The staple now goes into the glue hole as the stopper and the tube is now the handle .No more glue ups.[ATTACH]11349.vB[/ATTACH][ATTACH]11350.vB[/ATTACH]
2
Further I always use a cocktail stick to apply the glue.
3
I place a squirt of glue into the bottom reces of an upturned little jar, which has a concave surface this acts as a glue reservoir.
And dip into here as long as the glue is runny and usable.After the glue dries it will form a skin and not adhere to the jar Knock this skin off and start again [ATTACH]11349.vB[/ATTACH][ATTACH]11350.vB[/ATTACH] you will alway have a clean glue pot and surface to work with .Oh! the cocktail stick ,use a new one each time.
ugly 6 out
[ATTACH]21049.IPB[/ATTACH]
[ATTACH]21050.IPB[/ATTACH]
2
3
ugly 6 out
