Does anyone else use WD40 to lubricate their airbrush? I just had an incredulous response from a fellow modeller when I told him I did,he uses some expensive oil from Badger.
A little squirt at or swab of the air valve/trigger assembly followed by a little in the cup,sprayed and followed with my airbrush cleaner and everything is lovely and smooth for ages. It's never affected my paint nor airbrushes.
Try it,you'll be amazed. The last thing you need is a sticky trigger or needle when attempting really fine close up work.
WD40 is cheap and I bet you've got some in the shed or under the stairs already!
