Bought these blades some time ago & forgot about them.
Found that Morton blades are great but not I have found perfect for cutting masking tape when masking canopies etc.
So tried this blade & they are brilliant. Just one slice across, gently, cuts very cleanly thro. the tape. The blades are thinner than Morton, sharper & keep their edge better.
Also you are much closer to the surface than with a Morton so they give much better accuracy. Also been working much faster.
Almost makes masking canopies enjoyable.
[ATTACH]46135.vB[/ATTACH]
[ATTACH]49179.IPB[/ATTACH]
