Is this the same as the contacta glue with the metal tube applicator, used it before and bunged up the tube, reckon the glue had dried inside it, so I wasted half the glue because it wouldn't come out. Nice idea though.
the tube on this is much thinner and the cap has a peice that goes inside the tube when you put the top on so it never blocks, it dries perfectly clear as well
It's an acrylic cement used by jewellers for watch glasses and the like though it has found a niche in the hobby market too. I know one of SWMBO's friends uses it in the beautiful "doll's houses",sometimes shops etc,that she makes.
I bought some in Birmingham,probably in the jewellery quarter,but can't remember where.......old age I suppose.
It's readily available in the UK online,a quick google will turn up some retailers. It retails at about £3.60-£4.00.
Yes I have tried PVA Colin but it has never worked all that well for me. I find this Jewellers stuff a bit stronger.
Perhaps it is me but I find the stuff has a mind of its own & dribbles out unless you put the pin in which is a nuisance. I do not squeeze it in any wayAny body had this problem is so has any one solved it ?
Gator's Grip for me,just another acrylic cement. I did use the GS Hypo stuff for a while and it worked well enough but I mislaid it a while ago and have never found it. It probably got chucked out by mistake
I have a pot of Gator's Grip which has thickened up a bit over time and not only attaches clear parts but can be used to fill small gaps.
Steve you know that when it starts to go thick, you can just give it a few drop water and a good shake and its as good as new.. and you can reach it again :-)
