Where can I find factory drawings for Viper engined SE5a without breaking the bank?
SE5a
GuestTags: None
Do you mean the engine installation or the entire airframe? Google searches come up with plenty of information on converting to a Viper engined SE5a, including links to museums which house drawings but which are not available online for free.
Also, hi. -
Originally posted by \Do you mean the engine installation or the entire airframe? Google searches come up with plenty of information on converting to a Viper engined SE5a, including links to museums which house drawings but which are not available online for free.
Also, hi.
Just need a few basic measurements, e.g. length of fuel tank and distance between thrust line and datum. I`ve found a lot of info online, but a lot is conflicting and some downright wrong, so originals should give me what I needComment
Also, hi.Comment
They were museums etc with online catalogues, no online freebies. I don;t have time to look them all up again.
In the meantime you might like to look at the diagrams on this page which have dimensions:
http://flyingmachines.ru/Site2/Crafts/Craft25441.htm
Also lots of reviews and built threads online for Viper engined SE5a's.
And I haven't looked at it, downloaded it or anything but you can also try a download from http://www.epicmanual.com/pdf-pdfsource/royal-aircraft-factory-se5a-manual-vintage-aerodrome-59241/
It's hard to know exactly how to go about getting information isn't it? Are you building a flying mode, a static plastic model or what? There was a static very large scale SE5a built by a member on this very forum.Comment
Originally posted by \They were museums etc with online catalogues, no online freebies. I don;t have time to look them all up again.
have a look at outerzone there plans are free and most are in pdf form if you have adobe reader you can copy the plans to whatever scale you want no engine plans but loads of airframe kits worth a look if your into scratch building planes
http://www.outerzone.co.uk/Comment
