A little sad with my first model on large scales I decided to stop and start a new model. I hope this time goes. A Me 109 K4 on the scale of Hasegawa 1/32.
Is it that they open them to raise or lower but close when the wheel is in position? Could be the open ones in the pic are for maintenance or something. Just guessing really.....
Antonio I missed your post. The answer is that both are possible. There were problems with the retraction system for the tail wheel on this model so they were often fixed in a down position. By the time the K4 was produced different parts (including tail wheel assemblies) were being fitted and many airframes were upgraded making it difficult to say what exactly they were. Unless you have a good image of your aircraft you can't go wrong.
