My version of lead wire seat belts
    Here is how I scratch built some seat belts for a 1:48 Tamiya Mossie that I am building as a christmas gift for my ol' dad.
    Thick wire was rolled flat using a Tamiya paint pot. When I was happy with the width, I did a final roll on both sides using very fine sanding paper to give a texture.
    Thinner wire was used to make narrower straps. I used the kits decal seat belts as a rough pattern and cut up the pieces of rolled out belt to the desired shapes and sizes. Buckle plates, hooks, buckles and strap ends were shaped and all of the peices tacked together with superglue.
    Once primed and dried, the belts were painted deck tan and the hooks and buckles picked out in silver and black.
    I really like the way that you can shape the belts to fall over the seats to make them look more realistic. I am happy with the way they have turned out and look great to the naked eye.
  • john i am
    • Apr 2012
    • 4019
    Very nice Graham top tip thanks for sharing cheers John
    • Alan 45
      • Nov 2012
      • 9833
      Graham they look brilliant and so fit with the rest of the cockpit which is equally as good I might add
      • Vaughan
        • Apr 2011
        • 3174
        Great idea Graham can you show us the wire that you used?
          Here is an eBay link to the stuff I used. Various diameters....
          http://www.ebay.co.uk/itm/Plusmodel-Lead-Wire-1-0-mm-/191182255766?_trksid=p2054897.l5660
          • ojays
            • Oct 2011
            • 1713
            They also do bare metal and chrome self adhesive foil. Have used it on my R/C model planes in the past!
            Always a good service from this company.
            Gregg
              Great tip and great cockpit.
                Very nice Graham and as usual from you very inventive and innovative.
                I would however to be perfect, in my view, in places they need to be a mite thinner. In the first picture the bottom belt on the seat swab is to fat.
                I think if you could achieve this they would be absolutely perfect.
                My apologies for putting a spike in the wheel Graham.
                • monica
                  • Oct 2013
                  • 15169
                  nice Graham,they look Great,and what a good idea , thank you for sharing,
                  and the cockpit looks good as well,nice job,
                  • eddiesolo
                    • Jul 2013
                    • 11193
                    Great tip Graham, thank you.
                    Si
                      Fantastic! Thank you for the tip Graham
                        Hi, has anyone tried soldering wire with lead in rolled flat?
                        I'm having trouble sourcing the above wire .
                        Daz
                        • ojays
                          • Oct 2011
                          • 1713
                          I get mine from B&Q, although must admit I do a lot of soldering anyway!
                          Gregg
                            • 18269
                            I get mine from the foil caps on wine bottles...
                              I get mine from B&Q, although must admit I do a lot of soldering anyway!Gregg
                              Hi Gregg, so are you saying you roll the solder flat as well getting the same effect ?
                              Daz
