Ever wanted a special size control horn for your model ? well there is an easy way to make them from 'L' shaped alloy extrusions,first mark and drill the holes for your control links,then the mounting screws in the base,now with a junior hacksaw cut out the parts,fettle with a file and you will have the strongest control horns you will ever see.
Ideal for unusual gearing of controls and those ever increasing large models.
