Help with understanding Tamiya manuels
    Not sure where to ask but i had a question about Tamiya manuels. They are mostly in japanese and have confusing paint schemes such as XF-3:2+ or XF-3:2+ FX-5:1. These are very confusing, anyone know what they mean? Heres a quick link to a manuel online as a visual.
    http://www.tamiyausa.com/pdf/manuals/61061ml.pdf
    Thanks
    • 18269
    The instructions being in Japanese is due to your local hobby shop is buying from Japan and not the US Importers..
    The XF -bit refers to Tamiya paint colour codes.
    • Alan 45
      • Nov 2012
      • 9833
      The terms XF and the numbers are the paint numbers this site will tell you the paint colours
      http://www.tamiyausa.com/articles/feature.php?article-id=72#.U_4kJGK9KSM
        Originally posted by \
        The terms XF and the numbers are the paint numbers this site will tell you the paint colourshttp://www.tamiyausa.com/articles/feature.php?article-id=72#.U_4kJGK9KSM
        Sorry, I forgot to mention i understand the paint numbes what I don't understand is XF-3:2+ or XF-3:2+ FX-5:1. Are they ratios?
        For example I know XF3 is yellow but why do they add "-" to make XF-3 and what is the :2 for? Which end up making confusing codes such as
        XF-3:2+ FX-5:1
        • stona
          • Jul 2008
          • 9889
          Yes, they are ratios. They will give you what Tamiya considers the correct colour from their paints.
          • Gern
            • 9218
            Sorry, I forgot to mention i understand the paint numbes what I don't understand is XF-3:2+ or XF-3:2+ FX-5:1. Are they ratios?For example I know XF3 is yellow but why do they add "-" to make XF-3 and what is the :2 for? Which end up making confusing codes such as
            XF-3:2+ FX-5:1
            Like Steve says, they're the ratios for mixing their paints.
            XF-3:2 + FX-5:1 means two parts of XF-3 and one part of FX-5
            Gern
