Wheel hubs, the fast way!
  • Adrian "Marvel" Reynolds
    • Apr 2012
    • 3008
    I picked this little tip up from another site and thought some of you may want to try it if you haven't already.
    My pictures don't show it as I had already started to paint in the wheels before I saw the post but the entire tyres are painted your preference in colour, I use Tamiya XF-85 Rubber Black.
    The circle template is then used to find the right size diameter and then masked off around the relevant choice.
    [ATTACH]90313.IPB[/ATTACH]
    [ATTACH]90314.IPB[/ATTACH]
    You can use a little blutack to hold the wheel in place if you don't fancy holding it in place yourself.
    Make sure you spray it straight on then remove the tyre.
    If like these tyres the rims are recessed a little you may get some over spray on the rubber of the tyre, simple make a thin wash of the colour your using and let the capillary action take the paint to the wheel rim edges.
    [ATTACH]90315.IPB[/ATTACH]
    [ATTACH]90316.IPB[/ATTACH]
    I honestly think its so much faster than having to carefully paint in the rims or taking ages making masks.
    Adrian
  • john i am
    • Apr 2012
    • 4019
    Yes Ade a great tip I've being using this method for a while now after coming across this stencil one day in whs I did share a few weeks ago on someone's thread a great time saver with nice crisp results for all who are not doing this go get yourself a stencil and do wheels in seconds.i just put my wheels onto a piece of kitchen towel hold stencil over wheel using finger pressure spray, dry with hair dryer flip it over and repeat I haven't timed myself but I reckon less than a minute a wheel. The ones in my pic have had a dry brush and wash added also using the stencil which prevented the wash going on the tyre [ATTACH]90317.IPB[/ATTACH]
      • 18266
      I think it was on here you saw it Ade. The other forum must have nicked it off us
        • Apr 2012
        • 3008
        Haha yeah. I was on Flory's forum when I saw his video showing it
        • yak face
          • Jun 2009
          • 13836
          • Tony
          There are other forums ?!!
            • Apr 2012
            • 3008
            Hard to believe I know but it is a really useful site for me for video tutorials and reference builds and he now holds a live show every Tuesday night.
            Adrian
            • monica
              • Oct 2013
              • 15169
              nice tip Adrian, thank you, i have been using that way for a bit, forget who,said it maybe Aaron or Polux,
              sorry if i have the name wrong
                I have just used another way for the first time Adrian. Thin Revell anthracite 50% (for the tyre black) then just trickle with a brush down the sides of the tyre. The paint runs into the rim of the tyre. After it has dried paint the remainder with normal paint thickness and the painful cutting in to the rim with paint is not necessary.
                Got that tip also from here somewhere.
                Agree on Flory some good tips and they are demonstrated in film which is 1000% better than reading how to do it.
                Pity that no one has produced any demonstration film work.
                • Dave W
                  • Jan 2011
                  • 4713
                  I have just used another way for the first time Adrian. Thin Revell anthracite 50% (for the tyre black) then just trickle with a brush down the sides of the tyre. The paint runs into the rim of the tyre. After it has dried paint the remainder with normal paint thickness and the painful cutting in to the rim with paint is not necessary.Got that tip also from here somewhere.
                  I use Laurie's method.Think I remember Tony (Yak face) demonstrating it on here.
                    That is a really great method. However, For people who don't have airbrushes, just run some thinned paint around the wheel hubs, letting the capillary action take it round the wheel. The same is done for the inside, and the rest is painted
                    • flyjoe180
                      • Jan 2012
                      • 12390
                      • Joe
                      • Earth
                      What's this Laurie? Use of a weasel stick? Good tip, think I will try that.
                          • Apr 2012
                          • 3008
                          Your all missing the speed issue, you spray the entire wheel what ever black you prefer, few seconds to dry, then hold the wheel under the hole and spray the hub, done, simples, no need to paint and wait on tyre then carefully use a thin colour to fill in.
                          Adrian
                            Yes Joe and John. A very senior moment. ops: I let my self down. The mantle slipped. Two compressors the old one and the new one both sitting there who would not use a stick.
                            Adrian my adopted method is only for those who have a series of broken compressors. o_O
                            • eddiesolo
                              • Jul 2013
                              • 11193
                              Calm down...they be joking, no other forums exist...honest...
