Hi guys,
Thought this might be of interest.
I have been lucky enough to have had a small area to set up a spay booth/painting area.
Unfortunately due to having to have it near a window to vent the booth and the layout of the room I was quite restricted for space.
As you can see not a lot of space to work ? (I had moved the extractor at this stage but it sat in the corner).
I had a desk given to me but the only space to put it was on the opposite side of the room well away from the window. So I have been looking for solutions and saw a few tutorials on YouTube showing how to set up a bucket filter.
I purchased a 10litre bucket with a sealed lid.
The extraction pipe which would usually be hung out of the window needs to fit into the lid so a suitable sized hole was cut out.
You might see I have marked where it needs to go, I then drilled around the circumference to create a suitable sized hole.
A series of ventilation holes were then drilled around the edge of the lid before the extractor pipe was sealed into place with standard silicon sealant.
The pipe needs to hang about 2/3 of the way down into the bucket. A small amount of water is the poured into the bucket to sit just below the level of the extractor pipe.
The top of the bucket then needs pieces of filter gauze added to the lid, covering the previously drilled ventilation holes.
The theory is that the paint particles fall onto the water while the filter catches any that don’t ?
This is pretty much job done, I added a drop or two of scented oil to the water which creates a pleasant smell ?
So this is my new spraying area.
Much more room to work ?
Hope this helps if you are stuck in a similar situation.
Geoff.
Geoff.
