Natural Modeling Vegetation.
    The work bench rest on silence; is like a magic moment...
    You are opening a new kit box. The hands are observing the sprues, decal sheets and the instructions...perfect!
    Days or maybe weeks, a hard job remains ahead, but in your mind the imagination starts to work. A subtle image of the model is appearing... chipping hull, streaking grimes, dust effects,... And then you start to work over the idea.
    But...don’t forget anything...?
    You will leave all this effort over a stash or on a simple base with artificial green grass only...?
    The vegetation is the perfect complement to describe and explain, to the others, the story of our model.
    Is spring? Or maybe autumn?
    The vehicle is running on a desert? On a jungle?
    Pay more attention with the vegetation could be the difference between a good model and a magnificent model
    There are some brands that produce interesting aftermarket stuff, and at difference scales as well.
    Anyway, this thread will explain some varieties and tips, but only, about the natural vegetation.
    So, my proposing is inviting you to take a walk around the forest or on a simple garden. Just observe and take your time... You will discover a new world, which can be very useful for our hobby.
    The PART I of this thread will content only a few samples about what can we use as vegetation, natural vegetation...
    The PART II of this thread will content how to work them. Tools, glues and other tips.
    The PART III of this thread will content the paintwork. Paints, effects, inks,....
    The best way is experiment with your own flowers...so; take with you some little boxes and a scissors....
    There are forests all around the world!
    Polux
    Internet makes the world seems to be a small place, but that’s not true. The world has his own order and rules....
    There are different climates, seasons and places at diversity of altitudes... So, every place is unique!!
    With these conditions is difficult to explain which one is the best period to recollect our stuff...
    My recommend is simple; forget for a moment the frenetic rhythm of the civilization and their IPhones. Use the instinct, walk calmly and be observer and don’t forget the big trees or similar, like an eucalyptus...his dried rind is perfect for many different manual works, where I include the modelling
    On the next thread you will find a lot of diversity natural dried plants. Not works for all, but a good thing is keeping the flowers drying on the original plant. The future stuff will be more resistent and it’s more easy and safe to guard.
    For a better visual scale and reference for you, I used a 1/35 figure (50mm aprox).
    Remember that the possibilities are infinities...this is only a few part!
    Ok!! Let’s do a walk around the forest!!
    [ATTACH]105518.IPB[/ATTACH]
      This is maybe the most used plant around the world....the thyme. Is the perfect one if you are afraid to build your own tree. The colour, once dried, looks a lovely old trunk that floats over a river...
      [ATTACH]105526.IPB[/ATTACH]
      There are some similar plants, like the fennel, that are perfectly for his size and you can use for different scales like 1/72, 1/48 and 1/35.
      [ATTACH]105527.IPB[/ATTACH]
      [ATTACH]105528.IPB[/ATTACH]
      [ATTACH]105529.IPB[/ATTACH]
      [ATTACH]105530.IPB[/ATTACH]
      [ATTACH]105531.IPB[/ATTACH]
      The dried leaves of fennel are a good item as well. Be careful, is very delicate!
      [ATTACH]105532.IPB[/ATTACH]
      This one is... one of my favourites. Is really resistant and the detail level is amazing!
      [ATTACH]105533.IPB[/ATTACH]
      With that one you can choice how long it could be. Is a classic
      [ATTACH]105534.IPB[/ATTACH]
        After a few changes and a bit of work, this one will look like a lovely coloured flower.
        [ATTACH]105535.IPB[/ATTACH]
        The heather, once dried, is a delicate plant, but we can use three parts of them.
        The flower is perfect item for a spring scene. The flower is white, so is perfect for future paintwork.
        [ATTACH]105536.IPB[/ATTACH]
        The trunk of the heather is a good option, as well, for add detail at a winter tree. (This is a tree with a metallic structure (home made). The heather trunk at the end of the branches add more realism)
        [ATTACH]105537.IPB[/ATTACH]
        [ATTACH]105538.IPB[/ATTACH]
        You can use the leaves, well.... as a leaves on the soil. If you have patience, you can add them at some dried plants for an extreme realism!
        [ATTACH]105539.IPB[/ATTACH]
        Or add natural or artificial stuff to it to create a nice shrub.
        [ATTACH]105540.IPB[/ATTACH]
          Some modellers use oregano as a leaves. If you need to fill a forest scene, this is your plant
          [ATTACH]105541.IPB[/ATTACH]
          If you are looking to fill the soil on an autumn’s forest scene, the dried and crushed geranium leaves are perfect.
          [ATTACH]105542.IPB[/ATTACH]
          Some mosses are very resistant and they keep the colour.
          [ATTACH]105543.IPB[/ATTACH]
          [ATTACH]105544.IPB[/ATTACH]
          If you are looking for an aquatic scene those ones are good options. The second one is the rosemary leave, the advantage is that you can choice the size (all the leaves on the plant has different sizes). You can cover with clear resin for a nice alga effect on a river or sea.[ATTACH]105545.IPB[/ATTACH]
          [ATTACH]105546.IPB[/ATTACH]
            What about this dried flower? You only have to pull out the parts that you need to create a new plant.
            [ATTACH]105547.IPB[/ATTACH]
            Some trees give an interesting range of stuff. Observe this useful fruit; it gives to you an excellent little flowered grass.
            [ATTACH]105548.IPB[/ATTACH]
            Or the laurel and his flowers as well.
            [ATTACH]105549.IPB[/ATTACH]
            You are a Sci-Fi builder..? You want to recreate an Alien scene?
            [ATTACH]105550.IPB[/ATTACH]
            These plants are really delicate, but are perfect to reproduce the typical vegetation climbing on the walls.
            [ATTACH]105551.IPB[/ATTACH]
            [ATTACH]105552.IPB[/ATTACH]
            Of course, don’t forget the roots
            [ATTACH]105553.IPB[/ATTACH]
            These are only some options!
            Now is time to work with them. Let’s do it
              A pearl...
              [ATTACH]105554.IPB[/ATTACH]
              • Richi72
                • Sep 2013
                • 1100
                Great job Polux super informative this is, and thanks for taking the time to do this.
                Cheers Richi
                • monica
                  • Oct 2013
                  • 15169
                  agree total with Richi,very well put together and show,and explained as a picture is a 1000 words
                  very well done,
                    • 22770
                    Some very interesting ideas Polux a great thread also
                    • john i am
                      • Apr 2012
                      • 4019
                      Great thread very helpful and informative
                      • tanktrack
                        • Jun 2012
                        • 1429
                        love it
                          Thanks for sharing Polux
                            Nice job. Very useful for diorama people
                              Keep it up very useful thanks a bunch.
