Superglue debonder
  • Gern
    • 9204
    Superglue debonder
    Just a quickie folks. Does anyone know how long it takes for superglue/CA de-bonder to work? All it says on the instructions is to apply the de-bonder and wait until the glue softens. That was 20 minutes ago .....
  • eddiesolo
    • Jul 2013
    • 11193
    Dave, bung the piece in the freezer for 20 mins, that should break the bond, CA has a poor shear force-do not try and pull twist gently from the side and it should just pop apart. The cold accelerates the process.
    Debonder should have started working after 20 mins, however the warm day may have evaporated the solvents quicker.
    Si
      Tried the debonder. Not impressed. If it is attached to paint I think CA buries itself in the paint. So that is not good as there will be a mark or the paint film will come away.
      So pessimist. o_O After 20 mins the debonder has dried out got it to work sort off after a minute. Seems a lot depends on the thickness of he CA plus how long it has been there.
      Sorry Dave no help at all on the positive side.
      • colin m
        • 8730
        • Colin
        • Stafford, UK
        Freezer, hang on, what if Dave is typing one handed, because the other is bonded !
          May be he is stuck to the desk and can't reach the freezer, will have to kit bash all night.
            If he's stuck to the desk will it even fit in the freezer . What if he's got the glue on his hand and it's stuck to the outside of the freezer or what if he dropped some on the floor after a bare foot modeling session andstepped on it can he reach the jack hammer. Oh the suspence its killing me.
            • Gern
              • 9204
              Just to put us out of your misery Ken, none of the above! It just didn't work so the bits I stuck together are staying together!
              • eddiesolo
                • Jul 2013
                • 11193
                Poo, worth a try Dave.
                Si
                • james pithouse
                  • Dec 2014
                  • 1295
                  glad you did not use gorilla super glue you'll never get that apart then you'll be really stuck
                  Gorilla Super Glue is a super glue that keeps holding strong, even when the bond takes a hit. Just hold in place for 30-60 seconds while the formula sets, no clamping necessary.
                  Features include:
                  IMPACT STRENGTH - unique rubber particles increase impact-resistance and strength to handle everyday use after your repair or creation is set.
                  WON'T CLOG - anti-clog tip with metal pin keeps nozzle clean.
                  EASY TO USE - thick formula flows better for improved control. Dries in just 30-60 seconds, with no clamping.
                  WHATEVER THE SURFACE - use on nearly anything, from wood, metal, ceramics, some plastics, rubber and a whole lot more!
                  • james pithouse
                    • Dec 2014
                    • 1295
                    and it does what it says it does
                      Is that what its called nowadays??? Used to be bashing the....oh nevermind!
