Engine fit problem.
  • Marc Stock
    • Jan 2015
    • 664
    Engine fit problem.
    Hi guys i have come across a small issue. The 300sl build i am doing is taking shape and i have spent alot of time and attention on making sure i do a good job.
    I have spent the last 4 days making the body look perfect, i did a test fit this morning before going to work and now the engine hits the bonnet when i place the body on the chassis.
    Im sure it was okay before i painted, is there any way i can keep the paint on the underside of the bonnet and somehow slightly soften the inlet manifold with a hair dryer and push it down a little? Or am i going to have to remove paint from.under the bonnet?
    Its just under 1mm out.
    [ATTACH]123794.IPB[/ATTACH]
    [ATTACH]123795.IPB[/ATTACH]
    Certainly is strange...
    You don't can move the engine? Between the engine and chassis...
    Or just add a 1mm piece where the chassis join to the body...
    All the work looks very fine, so is a pity if you have to remove the paint!
      I can't see how paint would make a 1mm difference, are you sure the engine is sitting on its mounts properly, if it was okay before you painted it, it must be a physical fit problem, there is no way paint alone would make a 1 mil difference paint layers are measured in microns, I'm sure you will figure it out.
      • Marc Stock
        • Jan 2015
        • 664
        I managed to get it to fit. I had to file the underside of the bonnet took quite a bit of plastic out, the inlet manifold and airbox was stopping it from closing. I also pushed it down a little and that also helped a bit. Ill touch up later on
