How I Scratch Build A Ruined Building.
    When you look how your building started off to were it is now you'd never guess how it was put together keep up the good work sir, its better than watching Blue Peter,(remember when they used to make allsorts with sticky back plastic or is that me just showing my age.)
      Originally posted by \
      I,m enjoying see how you do it,as I can always pickup some tips and tricks,
      as you go along,
      I do my tiles,1.5 mm T x 12mm W x 15mm L, and over lap by 5mm,
      Thanks Monica,I can't remember the size of tiles I used for the last building I did but they are near the measurements you use.I have some left over,I'll have to get them out of my bits box.
      What, no wallpaper Loving this project Ralph.
      Thanks Graham,glad you are liking it.I thought as I did wallpaper on the last one I would have paint on this one.
      Looking so good and to say few would think of this ( I'm really thinking of building a building now.
      Need to do the calculations to make in 1/35.
      Love the beam work and wall covering.
      Really nice
      Thanks Robert,I'm glad it's making you think of doing one for yourself.
      The calculations you need for 1/35 are 9mm to the foot,so a standard 6 foot door would be 54mm high.
      Robert
        Thanks so much for your comments Kevin.
        I remember watching Blue Peter in the 70's and all the things they made.I must be getting old too
          I added the floor boards using the same wood as the window's.
          I then added the same wooden strips to the roof to hold the tiles.
          Ralph.
          • Robert1968
            • Mar 2015
            • 3596
            #65
            Thanks Ralph for the dimension conversion. I plan to build a destroyed barn in say Russian ( winter ) for my Jagdpanzer IV Lang but research will need to be done as in units type of barn etc and age of barn/type etc.
            I may need to look at wooden beams and your dimensions are going to help me immensely.
            Regards
            Robert
              This is coming along quicker than I thought.
              I then started to put on the tiles.
              These were made using 0.5mm sheet,cut into rectangles of 10mm by 15mm.
              pics show first 2 rows.
              Ralph.
                Ralph this just gets better and better realey informative it gives people something new to try,another string to one's bow as they say.
                • monica
                  • Oct 2013
                  • 15169
                  #68
                  looking great ,Ralph,do like the way your done the roof,
                    Thank you for the kind comments Kevin.I always like and try to give something to the hobby.
                    Thank you Monica,I'm glad you like it
                      Added the rest of the tiles.
                      I also added the barge boards using 0.5mm plastic and wood used for windows.
                      Door frame also added using same wood as windows.
                      Ralph.
                      • monica
                        • Oct 2013
                        • 15169
                        #71
                        looks great ,Ralph,and glad that you added in the barge boards as well,
                        real has turned out well,good work,and useful help,
                          Thanks Monica,your support is much appreciated.
                            One of the next things I did was to start the base itself.
                            Using MDF.I edged this with 1mm plastic sheet.
                            On top of the MDF I used Will's York stone paving.a recess was cut out for the building.
                            The building was then glued in place and the ground floor floorboards were added(same way as the other floorboards).
                            The next thing I added were some stone steps in front of the doorway.
                            Cheers.
                            Ralph.
                              Ralph your attention to detail even down to the skirting boards upstairs is brilliant,keep up the good work mate,looking forward to your next installment, Kevin.
                                Thanks Kevin,appreciate your kind words.
                                Just a few more things to make then I'll be painting the rest.
