Sanding Sealer is getting a bit difficult to get hold of these days but is easy enough to make yourself,all you need is ordinary clear dope,some cheap talcum powder,oil of Wintergreen and a little glycerin,add enough talc to the dope to just make it fall off the brush,add a touch of th oil of Wintergreen to stop any blooming and then a dash of glycerin to make the material slightly elastic and avoid any brittle dry out,you will find this mix to sand down really well,once done use a tack cloth ( lint free cloth with dab of clear varnish ) to get rid of the dust and apply a second coat for a superb finish all ready to take paint.
How to make Sanding Sealer.
thanx wonwinglo, someone had suggested i use a sanding sealer, but i have no joy in finding any
i`ll give this a try next weekend.
oil of wintergreen ? , will that be available ffrom a chemist ? -
Could you be a little more specific on the formula/proportions of ingredients to make sanding sealer? Is lacquer the same or a good substitute as "dope"? What is dope anyways? What is "blooming"? How do you know how much glycerin to add?Comment
regarding the sanding sealer
what is the ratio mixed talcum, wintergreen oil and glistering , after applying 2 quotes of sanding sealer , can we spray on a surface of NC WOOD STAIN AND WOOD LACQUER ?Comment
