So I'm looking to custom print some decals, and from what I can gather laser is preferable to inkjet for them. However my local print shop is cautious about using decal paper because they're concerned the plastic layer of the paper melting in the printer's heating element and damaging the machine. From what I can gather, this can happen (look at the first couple of reviews here) and I don't want to damage their printer or be left with a hefty repair bill. Can anyone recommend any particular brands of decal paper or methods of printing to ensure that this won't happen? Is there any advice that people can give me about printing them?
Laser Printing Decals
GuestTags: None
The advantage of laser over inkjet is you don't need to seal them after printing, you can get laser specific paper that shouldn't damage the printer.
I have 3 sheets of A4 clear in stock that you can have for a couple of quid.Comment
Thanks for the offer, but my print shop won't print them unless I can get some sort of confirmation that it won't cause any issues. Getting the paper itself seems to be a secondary issue right now.Comment
Laser - ? - Absolutely no way...
I've been printing decals for over 10 years.
Inkjet are infinitely better in colour and resolution.
Laser are very poor by comparison.
OK - Laser need no clearcoat but they are dull and quite fuzzy by comparison.
I have a ยฃ600 HP laserjet pro and the decals from it can't touch those from my little ยฃ80 HP Deskjet 1000.
I print decals for model cars and text of less than 0.5mm on engine decals is completely sharp and fully readable under a lens.
With the laser, the text is just a blurry line.
Inkjet colours are sharp and vibrant
Laser are dull and washed out.
I coat my inkjet decals with Plastikote clear gloss varnish and they are excellent.
All of the decals on my Lotus F1 conversion (Revell Ferrari base) are inkjet, created by me. They are razor-sharp. (Sorry the pics are a bit naff - old cheapo camera at the time)
Nope - sorry. Inkjet for decals every time.
That's interesting. My inkjet printer is a Canon MX920 which seems to be fairly decent, and the prints I get out of it are in awful quality. I get white printer lines left and grainy parts. Not tried laser yet though so can't comment first hand.Comment
Thanks for the information. I've also got a couple of concerns about printing. I've come across a couple of instances where four-pass colour printers warp or deform the decal paper or damages the printer. Is it worth specifically going for a single-pass printer out of it?Comment
[ATTACH]261189[/ATTACH]
[ATTACH]261188[/ATTACH]Comment
I pr0duced some inkjet decals for the first time recently and they look good. Very sharp. At first I responded to a warning by the paper suppliers not to put too thick a coat of acrylic varnish on them, or they might not soak off the backing. Two light coats (as instructed) and the colour (including black text) ran a little and the text has a pink tinge. So, three coats or more next time. Need to practice.Comment
All decals on this Subaru were laser printed. The printer will not be damaged by laser decal paper. Colours are bright and the quality is perfect. No need to seal the decals either before use..
