Building cars!
    Building cars!
    Hey all!
    I have 3 model cars that I am due to build within the following months. They are:
    - Airfix Aston Martin DBR9 (1/36)
    - Tamiya F1 Honda RA-272 (1/20)
    - Tamiya F1 Lotus Coventry-Climax 25 (1/20)
    I have only done two cars in scale (when I was around 12-14 years old) and obviously being that age and didn't know the tips and tricks they didn't come out fantastic.
    Now that I am returning to cars I have been reading up on how to do them properly! Some processes I have read are WAY to complicated but some I have seen seem ok. I like things done simply and not over-complicated.
    With the car shell I know to:
    1) Wash the plastic in soapy warm water to get rid of any oils
    2) Spray Primer
    3) Spray colour of car.
    My questions are:
    1) How many coats of each is enough?
    2) I have read everywhere that Tamiya Clear coat spray eats away the paint when sprayed on when dry. I saw a video online of someone doing the Honda and they use a polishing compound.
    How can I spray the car body to achieve a great result?
    Cheers!
    Hi Stefan !
    You can check my blog on Scratch Laboratory adn see if it was of any use to you. I hope I will be able to post some new threads soon.
    Best regards,
    Chris
      Hi Stefan!
      If you are after that shiny glossy show-room paint job, there is on way around doing multiple coats of paint and clear with lots of sanding and polishing in between. I start out washing and sanding the parts, then I prime. Before first coat of paint I wet-sand the primer (Grit1000-2000), Depending on colour I put between 5-10 coats of paint with wet-sanding in between. And after that an equal number coats of gloss-clear with lots of wet-sanding between layers. For the grand finale I use coarse and then fine polishing compounds.
      Check out Alex Kustovs tutorials here:
      Preparing Plastic Kit for Paint
      and here:
      How to Apply, Polish, and Wax Your Paint to Perfection
      Generally his web-site is a gold-mine of tricks and inspiration when it come to car modelling.
      Good luck!
      /Daniel
        • 18269
        Originally posted by \
        Hi Stefan !You can check my blog on Scratch Laboratory adn see if it was of any use to you. I hope I will be able to post some new threads soon.
        Best regards,
        Chris
        Or instead of promoting your own web blog, you could for example give a worthwhile reply here.......
        (Vi are Vatching you, Ya!)
          Or instead of promoting your own web blog, you could for example give a worthwhile reply here.......(Vi are Vatching you, Ya!)
          OK, I ll do that next time !
            Cool! Is sanding the entire car body required? What does it actually do?
            Hi Stefan!If you are after that shiny glossy show-room paint job, there is on way around doing multiple coats of paint and clear with lots of sanding and polishing in between. I start out washing and sanding the parts, then I prime. Before first coat of paint I wet-sand the primer (Grit1000-2000), Depending on colour I put between 5-10 coats of paint with wet-sanding in between. And after that an equal number coats of gloss-clear with lots of wet-sanding between layers. For the grand finale I use coarse and then fine polishing compounds.
            and here:
            Good luck!
            /Daniel
              Thanks for the link to ur site and them Alex Kustovs tuts! They are fantastic!
                Hi Stefan !
                Yes, sanding the entire car body is a must - it will remove any imperfections left after molding process. After the first layer of primer - I suggest it would be a dark one - you will get a better contrast and most probbably see some other imperfections that could not be seeen before. The same goes with the "wet coats", especially the last one - polishing will give that extra shine. Otherwise, it is "just" a painted plastic !!!
                As I said before, do not be afraid of eventually not having "fancy" equipment nor materials. Go gradualyy and with patience.
                Best regards,
                Chris
                • Andy2035
                  • Aug 2011
                  • 730
                  Check out Alex Kustovs tutorials here: Preparing Plastic Kit for Paint
                  and here:
                  Good luck!
                  /Daniel
                  Hi Daniel,
                  Many thanks for sharing them links, most helpful...:flower:
                  Andy...
                    Hi guys and girls
                    Does all this coats of primer and paint not start to hide the detail lines of the car? eg. the door handles
                      • 18269
                      Well Troy, the idea is to only put down very thin coats of paint. But it is always a risk that you can swamp the detail with to much paint.
