Sea Foam
  • JR
    • May 2015
    • 18273
    #166
    Originally posted by Jim R
    Hi John
    The stickiness was really only on the leaves, what I have now is pretty dry. I have not saved seeds as I have a lot left in the packet I bought to start with. When they are used do you airbrush them and add foliage?
    Jim.
    Yes air brush some base colour on, light browns etc, I would most likely do Silver Birch, with white and a little dark brown. Once dry spray either with Hair spray, or a matt varnish, then holding over box/ tray sprinkle the foliage as normal . Although resilient they do need care. When using on a base, drill , spot of pva in the hole and stick in. If I do as Richard suggests you will be finished about 2200:smiling2:
    John .
