Hi this is how I make my palm trees hope you find it helpful.
The trunks and branches are made using copper wire ( I have use cooker wiring it has 7 strands but anything will do), the leaves are made from 1" ordinary masking tape. The trunk are wrapped in Das clay and then textured.
Lower branches are cut to 10" long.
Leaves x 7 are made from 1"x5" masking tape, mark halfway 2 1/2". Lay copper wire in the centre and double over the masking tape back onto itself, cut a palm shape and feather the edges of the leaves to finish. Paint to your own colour specifications.
Feather all the edges of the leaves .
Trunks, cut is to 11" long.Tape one end and at 3 1/2" in from the other, then carefully splaey the wires out to make the top branches, the leaves are made in the same way as the lower ones.
Paint all the leaves before assembly.
Bend all the leaves to shape.
I've used Das clay and moulded it around the copper wire to make the trunk then formed the palm tree shape into the trunk.
Paint the trunk and weather with oils.
I used a dish pad for the palm fronds.
Then add trees to your diorama base.
Thank you for looking.
Pete.
Pete.
