Making tarps the easy way.
  • colin m
    • 8750
    • Colin
    • Stafford, UK
    #16
    That is so easy, it made me laugh.
    • scottie3158
      • 14201
      • Holbeach
      #17
      Thanks for all the feed back. I tried a few different varnishes to check there was no issues. Then I tried CA it does melt the film a certain amount so I applied the CA to the model then pressed the roll to this and it worked fine.
        Hi Paul I thought I'd try your PVA glue tarpaulin tutorial only my first go and it came out pretty good will certainly have another go thank you.[ATTACH=CONFIG]n[/ATTACH][ATTACH=CONFIG]n[/ATTACH][ATTACH=CONFIG]n[/ATTACH]
        Well impressed.
        Pete :thumb2: .
        • Strenko J
          • May 2018
          • 752
          • Joe
          • Pittsburgh PA
          #19
          Thanks for the tip on this Paul,, will definitely have to give it a go
          • Andy Belsey
            • 887
            #20
            I would have missed this had Pete not bumped it up to the top!
            Thanks Pete, but THANKS Paul!
            Andy
            • scottie3158
              • 14201
              • Holbeach
              #21
              Well impressed.
              Pete :thumb2: .
              Pete,
              Glad it worked for you.
              • scottie3158
                • 14201
                • Holbeach
                #22
                Joe, it does seem to work as to the longevity only time will tell.
                Andy
                Andy, The other advantage I suppose is you can make them as thin or as thick as you like by just adding coats of glue.
                • GerryW
                  • Feb 2021
                  • 1757
                  #23
                  Bookmarked this (just so I can find it when I need to!)
                  • Fernando N
                    • 2448
                    #24
                    Excellent tip, thanks for sharing Paul :thumb2:
