HELP my photos are awful
  • scottie3158
    • 14197
    • Holbeach
    I need help from those of you that can take a decent picture. I normally just leave my camera in auto. Even when I use my light box they are still terrible. If I want to select manual what f stops etc should i be looking for or is it not that easy. Please remember you are talking to someone who is photographically challenged.
    Scottie, do you use an editing app? On my computer, by right-clicking on the image in the pictures file I am given access to several editing functions, the best being 'photos' which allows you to lighten, re-colour crop etc. I use it all the time.
      Paul,
      what camera are you using? - Could you put up some pictures, to illustrate what you mean?
      • scottie3158
        • 14197
        • Holbeach
        Hi Peter I have GIMP 2 which I have used in the past. My problem is They are bad in the first place so would like to take decent ones so i don't have ti use them. But I guess that would be an option.
        • scottie3158
          • 14197
          • Holbeach
          Paul,
          Dave it is a Fujifilm finepix s i think they refer to them as bridge cameras. As to pictures just look at my liberty b pictures you will see what i mean.
            Just tried to pm you, let me know if it arrives.
            Mike.
              What kind of pictures do you want to take? I find that I can take model photos for posting to forums perfectly fine using my iPad, for example, but if you want extreme closeups, great depth of field, etc. then you’ll probably need a bit of a higher-end camera.
              The trick to using an iPad (or phone) for model pictures is, I think, to not try to get in too close. Since the actual photos you take have a much greater number of pixels than you need when posting to a forum, you can take the photos from further away and then crop them to what you actually need — right there on the tablet or phone if you want. This makes it easier to take decent photos, because when you’re not as close in, you can get more of the model in focus.
                Paul,
                I use a Fuji Finepix SL240 Bridge Camera.........................
                I've taken the Liberty ( get it? ) of taking two of your pictures & running them through my ancient PaintShopPro8.................Click image for larger version
ID:	1119989Click image for larger version
                I used a simple Automatic Photo Enhance Feature it has brightened up the pictures quite a bit.
                It could be that the camera is set to average metering - it may help to set it to 'spot' - its in the Photometry menu on the camera!
                • scottie3158
                  • 14197
                  • Holbeach
                  Thanks Dave I will try that tomorrow
                  • wotan
                    • May 2018
                    • 1150
                    Scottie
                    All good advice here from the guys. I would add two things.
                    First up try to arrange your lights to have one on each side of the model lighting it like this.
                    You can use pretty much any sort of lights, for instance your desk lamp on one side and an led flashlight on the other.
                    Secondly check if you can set your own White balance, on the camera. Your pictures are consistently dark and with a blue cast. The white balance can change this to a more natural colour.
                    Finally I would look into Dave's suggestion of going to Spot metering rather than average. This will allow you to meter on one of the darker areas of the model and hence get a slightly longer exposure which in turn will lighten everything up.
                    Here is what I did in photoshop to increase the exposure a little and to balance out the blue cast. This is all better done in the camera as suggested above.
                    Good luck
                    • scottie3158
                      • 14197
                      • Holbeach
                      Thanks John I will give this a try tomorrow
                        • 18882
                        Other tricks are as follows:
                        Use a high F number. This gives a larger depth of field so more of the image is in focus. A consequence of this will be that the exposure gets longer, so use a tripod and a remote release to stop camera shake. If you don’t have these, blue tac the camera to a suitable support and use the timer function. Don’t try to hand hold the camera as you won‘t keep it still.
                        Next, use a mid toned background. Using light or dark backgrounds fool the camera sensor into under or over exposing the image.....the sensor sets camera exposure so that the majority tone of the image is a mid grey. Photo shopping an image is useful, but it’s better to try and get the exposure right in the first instance....
                        Lastly, use the histogram....you need a good spread on this for a nice image....watch out for blown highlights as they are lost detail that cannot be retrieved. Better to shoot slightly under and brighten the image under post processing.....
                        cheers
                        Tim
                        • scottie3158
                          • 14197
                          • Holbeach
                          cheers
                          Tim
                          Thanks Tim you have given me a lot to think about.
                          • JR
                            • May 2015
                            • 18273
                            This why Paul I now use my phone ! :crying:
                            • rtfoe
                              • 9065
                              Everyones given you excellent tips so much so there is nothing to add except if you want to highlight any part just use a small white card or mirror to bounce light onto the part from your two main sources of lamp lights.
                              In photoshop I only use tone and color functions to balance for natural colors and only cut off total contrast and brighten if necessary. Tim has it right to watch out for blown highlights as this registers as nothing on pixels to to pick up or adjust from at post.
