How to make your own decals
    Not a clue how to go about this.
    I can prepare the JPEG image size & reze etc so that side is not a problem.
    Assume with the JPEG better to go for a larger pixel count.
    But after that side of matters not a clue.
    I have an HP Deskjet 3630 ink jet printer.
    What do I need & how do I do it . Info on that much appreciated.
  • PaulTRose
    • Jun 2013
    • 6442
    • Tattooine
    you can buy special printing paper.......white backed and clear backed, all depends on what you plan to print.................print as 'best quality'....let it dry then a light spray over with acrylic narnish to seal.........cut out as close to the pic as possible and dunk in water as normal
    ive done a few in the past but thay are always way thicker than a real decal
    Per Ardua
      • 18881
      Looks like this site might be worth a once over Laurie...
      Im going to have a look myself as you’ve piqued my interest....
      • PaulTRose
        • Jun 2013
        • 6442
        • Tattooine
        Per Ardua
        • BarryW
          • Jul 2011
          • 6008
          In my one experiment doing this I found them actually thinner than Tamiya decals and without the splintering issues you get with so many. Depends on what decal paper you use.
            Yes you are right Tim. You hear about things & think I must have ago.
            It is that thing when a young boy of seeing those sticky things in the bakers. Just got to try them.
              Barry what papers have you used & which is best ?
              Also which is resistant to "a pint".
                Larger pixel count is better, provided you don’t have to enlarge the image to get it. Enlarging doesn’t need to be a problem, but better to avoid it if you can, because it will reduce quality much more than reducing an image in size will.
                Also, JPEG is not a good choice of image format for anything that isn’t a photograph (or similar, like a scan of a painting) — the P stands for Photographic. If you have blocks of solid colour, geometric shapes, etc., using a lossless format like PNG (pronounced “ping”, BTW) is better than a lossy format like JPEG, because the latter discards and approximates pixels in order to achieve better compression.
                • Neil Merryweather
                  • Dec 2018
                  • 5180
                  • London
                  didn't know that about JPG & PNG Jakko, cheers
                    It’s mainly apparent if you look closely at hard colour edges that aren’t perfectly vertical or horizontal, especially in a JPEG with the compression level turned up high. I’m not at my computer now, else I could easily post some examples. Tomorrow
                    • Isitme
                      • Nov 2020
                      • 795
                      Hi Laurie,
                      Have a look at www.craftycomputerpaper.co.uk. Here you can get the paper you require either clear of white (A4), it comes with full instructions. I set my printer to photo for the best results. and cover the printed item with Humbrol crystal clear varnish. Mist the varnish on in three or four coats and set aside to dry.
                      Before you start print out your design of normal printer paper as this will tell you if it is right or wrong.
                      You can mask off the paper you do not wish to be varnished with printer paper so that only your image gets varnished, I usually allow about 15mm clearance.
                      Below are a couple of my decal sheets a bit blurred (photos) but the idea is there.
                      Mike
                      This is magazine covers, laptop keyboard and screen all to 1/35 scale.
                      Coca cola, Pepsi can labels and Evion water label.
                        Originally posted by Jakko
                        It’s mainly apparent if you look closely at hard colour edges that aren’t perfectly vertical or horizontal, especially in a JPEG with the compression level turned up high. I’m not at my computer now, else I could easily post some examples. Tomorrow :smiling3:
                        Jakko at the scale we are working to JPEG to PNG makes no difference it is only when you get to large scale as I used to in my architectural life that it makes a difference.
                        JPEG PNG or is PNG JPEG
                        Problem is if making up your own decal down loading pieces to use are mostly original JPEG . But it does not make any difference for the scale I certainly works to 1/48 & 1/72
                        The other difficulty is if down loading on line then you are up against it any way & that at these scales it makes no difference.
                        [ATTACH=CONFIG]n[/ATTACH][ATTACH=CONFIG]n[/ATTACH]
                          • 18881
                          Not sure which one of the chairs is which format, but they are certainly different Laurie. The right hand one is sharper with much better contrast and definition, at least on my iPad. The right hand roundel exhibits less aliasing on the circle edge. The colour shift is also obvious!
                            Interesting Tim.
                            The right chair is JPEG
                            The roundel top as downloaded.
                            The right one astounding loss of colour PNG.
                            The left bottom JPEG.
                              As a help just recommend Serif Page Plus.
                              This is a publication programme. It allows cutting away portions of a photo resizing. Adding text in various forms.
                              Also has a Photo lab where you can alter all the various parameters colour intensity saturation etc. etc.
                              Comes with a cut out studio this also automatically enhances edges ie fills in any lost minor bits. You can also add bit of the same colour etc. Change colour.
                              A whole host of other stuff. A superb easy to use. Great for personal birthday cards. Anything you wish to do with graphics you can achieve.
                              Cost on Ebay there are some good bargains. a PAGE PLUS 9 still in original packing approx £43. Good value.
