Engines,engines, engines
    Hi all some people have said they thought my engines looked very realistic (I think it helps in that most of my life I've been around or worked on either motorcycle or car engines) so I thought if anyone wants to know how I do any aspect of weathering an engine they could just ask or if it would help maybe I could try and post a video (pretty rubbish at social media)
    Here is a random sample of the hundreds of engines I must have modeled over the years
    [ATTACH]431412[/ATTACH]
    [ATTACH]431413[/ATTACH]
    [ATTACH]431414[/ATTACH]
    [ATTACH]431415[/ATTACH]
    [ATTACH]431416[/ATTACH]
    [ATTACH]431417[/ATTACH]
  • scottie3158
    • 14197
    • Holbeach
    Ken,
    Excellent results.
      • 15636
      Hi Ken
      They look superb. Details are great.
      • Airborne01
        • Mar 2021
        • 3935
        • Steve
        • Essex
        Obi One Kenobi.
        When I do my next Opel Blitz or Hanomag I'll ask permission to sit at the feet of the master - I'll even put two hard-boiled egg halves in my eyes for the first few minutes! Excellent!
          Hi all so the first installment, I'm basically the laziest modeler ever and if there's a short cut or an easy way to do something I'm there.
          So heres the first bit of aging an engine, since I'm working on an engine atm I decided to use that as the first example.
          First requirement talcum powder.
          [ATTACH]431808[/ATTACH]
          Here's our nice clean engine
          [ATTACH]431809[/ATTACH]
          [ATTACH]431810[/ATTACH]
          I use enamels so in this case I dip the brush in white spirit before picking up some talc(you can use water but you would have to matt the engine first as the water will just bead otherwise) I then dab the loaded brush on the engine (really load it all up with the white spirit and talc)once that's done flood with white spirit till it looks how you want.
          [ATTACH]431811[/ATTACH]
          [ATTACH]431812[/ATTACH]
          I used gun metal from ABT
          [ATTACH]431813[/ATTACH]
          To highlight the bolt heads.
          [ATTACH]431814[/ATTACH]
          I then dust it all with Uschi powders
          [ATTACH]431815[/ATTACH]
          Then buff that with a soft brush
          [ATTACH]431816[/ATTACH]
          [ATTACH]431817[/ATTACH]
          [ATTACH]431818[/ATTACH]
          My ref pic
          [ATTACH]431819[/ATTACH]
          This is going to end up being a very long post as I have lots of stuff to add to it (assuming you want it)
            • 18880
            Great stuff. I always find it interesting seeing how someone does something really well.
            • Mark1
              • Apr 2021
              • 4156
              Yeah keep it coming :thumb2:
              • JR
                • May 2015
                • 18273
                I'm in, engines are all ways open for weathering Ken, interesting to see how others do it .
                • PaulinKendal
                  • Jul 2021
                  • 1608
                  • Kendal
                  Ooh, this looks excellent! I'd not heard of Uschi - what a great finish you've achieved there!
                  • minitnkr
                    Charter Rabble member
                    • 7504
                    • Dayton, OH USA
                    ......partial to Fords & Porsches eh.
                      Partial to lots of engines Paul
                        Hi all well I have been given lots of ref pics of this engine and none of them are as distressed as this is, so a bit of white spirit and a cotton bud and it's looking more like it should.
                        [ATTACH]431958[/ATTACH]
                        So next method, here is the sacrificial engine for this example (and for most of the others)
                        [ATTACH]431959[/ATTACH]
                        OK as I said at the start of this I use mostly enamels so I can't say if this works with acrylics (although I've found in the past adding washing up liquid to the solution tends to have the same effect as white spirit)
                        If you want an engine that looks like it's been in a dusty environment (as in my mad to the max bike)
                        Get an empty tin or bottle into that pour some matt colour of the earth in the area your engine has been driving in ( for the mad to the max bike I used sand as it was set in a desert, for this I've used earth)
                        Add talcum powder to it and mix keep adding talc till you get paste like consistency then add white spirit keep stirring till you get the consistency of milk, add the talc to the paint first don't thin it till you've added the talc as the talc doesn't seem to take the colour if you thin the paint first.
                        OK so use a big brush and load it with this mixture and dab it all over the engine(really cover it so it gets in all the nooks and crannies, then load your brush with white spirit (this is the important bit hold engine as it will be in the car or bike and flood the engine with white spirit just let gravity do its thing.
                        [ATTACH]431960[/ATTACH]
                        [ATTACH]431961[/ATTACH]
                        This is how it looks when dry
                        [ATTACH]431962[/ATTACH]
                        All the plastic parts I dab with ABT copper oxide blue patina
                        And again blend with white spirit
                        I also add ABT engine grease anywhere you might expect an oil leak
                        [ATTACH]431963[/ATTACH]
                        [ATTACH]431964[/ATTACH]
                        [ATTACH]431965[/ATTACH]
                          • 18880
                          Among all the lunacy on here at the moment it’s nice to see some modelling has broken out. Great work and a very informative blog.
                          • PaulinKendal
                            • Jul 2021
                            • 1608
                            • Kendal
                            This is shockingly real. Makes me feel quite distressed for that poor Ducati.
                            • Mark1
                              • Apr 2021
                              • 4156
                              I've spent a lot of time around engines but wouldn't know how to get a model one looking so realistic, superb work.
