Hi All,
as the name of the thread says. How do you stick together two pieces of photo etched parts? I use quick glue and I don't struggle with large pieces. My struggle is gluing two small pieces like in example below:
When I was doing this I really struggled in setting parts PE30 to PE5. It was like trying to glue a tip of a needle to paper sheet vertically. Even with quick glue, no luck. Not to mention it's very easy to over do it with glue and when it dries it does not look clean and nice. Also in the example above there were no holes in PE5 part to help with holding the parts upright until the glue kicks in. The surface on which the glue has to act is very small for part PE30, like tip of a needle. I also noticed even larger pieces can be difficult if its metal to metal joint. If I have to glue metal to plastic its much easier.
Any tips and tricks for cases like these?
