Easy Dio Dry Stone Walls
    I came across some casting powder the other day, and a little bulb lit up, that reminded me of an article I once read on making dry stone walls for any scale dio's.
    1.Make a mix of your powder, casting,plaster of paris, poly filla etc.
    2.Then pour it in a tray, not to thick, then tap the tray to get the air bubbles out.
    3.When its near the setting mark, just dab your fingers lightly over the top to give it texture.
    4.Then when its dry, just crack them all up into little pieces.
    5.Then build your wall, to the style you want, I used PVA glue to set the pieces in place.
    6.When you have built the wall, I just mat varnished it before painting.
    6.Then when the wall is set, just paint it to the style and effect you want, after you have painted it, you can add pastel or weathering powders, I just airbrushed various Tamiya, greens and browns to give it a weathered out door look.
    I hope this is of use to you Dio builders.
    Thanks for reading all,
    Ray
  • spanner570
    • 15381
    Very nice weathering Ray.
    You should have added....
    Never use you bride's best Teflon non stick tray...I did, once!
    Now the scars have healed, I use the top of a 1ltr. ice cream container. Plenty big enough too.
    Ron
      • 18264
      That handy, I will be needing a dry stone wall for a base soon.....
      Looks very good Ray.
      • Centurion3RTR
        • Jan 2009
        • 2093
        Thats brilliant Ray, thanks for posting it up mate. Going to give it a go for my next project.
        Have fun, John
          Superb, nicely demonstrated too.
          Thanks for sharing.
            • 22770
            Great tip Ray
              Glad it may be of use to you super dio builders in the future.....and thanks for reading...
              @Ron ...lol..great tip mate.....rather shocked your still alive though....lol
                Great little method Ray ...
                I mainly use the polystyrene method but your idea has the edge for versitility thats for sure
                  Top tip, thanks
                  • spanner570
                    • 15381
                    Originally posted by \
                    Glad it may be of use to you super dio builders in the future.....and thanks for reading...@Ron ...lol..great tip mate.....rather shocked your still alive though....lol
                    Thanks for the concern Ray, the scar is still there but I wear a bobble hat to hide it!
                    Incidently, with regards to the 'Ice cream tray', the one advantage is that being plyable, you just gently flex it and out pops the stuff!
                    Another good moulding tray is the soft silicone baking tray.....The Pound shops and the like have them in various sizes and pretty colours too!!
                    Ron
                    • aaron
                      • Oct 2011
                      • 2019
                      Effective and easy this will look as good done with polyfiller i hope. Thanks ray.
                      The paint job and weathering looks perfect i might add. Spot on
                      • geegad
                        • Mar 2010
                        • 2329
                        oh yes will be using this in future projects nice one ray
                        geegad
                          It depends on the scale, but years ago I used some small slatey-like stuff piled on the roadside by the Local authority. By placing each piece horizontally produced a very realistic wall.
                          • mossiepilot
                            • Jul 2011
                            • 2272
                            Great tip Ray and thanks for saving me from SWMBOID (SWMBO inflicted damage) Ron.
                            Tony.
                              Ha ha ha....... classic !!!!
