corrugated sheets
  • JR
    • May 2015
    • 18273
    #16
    the two together are 0.19mm
    Thanks Neil, off to measure some container material.
    • rickoshea52
      • Dec 2011
      • 4076
      • Rick
      #17
      It seems that food containers are the only real material due to their thickness to use. I search the web for a thickness like them in sheet form but found nothing.
      Foil takeaway containers worked best for me.
        • 18891
        If you can’t get those 4D modelshop do both thin pewter and aluminium sheet that would be suitable.
        • JR
          • May 2015
          • 18273
          #19
          Hi Neil just measured 0.9mm and the foil for kitchens is 0.01
          • JR
            • May 2015
            • 18273
            #20
            Yes fully agree there Rick, there is some waste though in the sides.
            • JR
              • May 2015
              • 18273
              #21
              Thanks Tim use them quite often for Kappa Line, will check out the prices.
              • Blimp
                • May 2023
                • 64
                #22
                I have used empty toothpaste tubes before ,( they are now plastic :sad: ) Ex - glue , oil paint ec. are worth saving too. .
                • Gern
                  • 9212
                  #23
                  Try the foil from Ritz cracker boxes. It's much thicker than ordinary kitchen foil but thinner than the foil trays from your favourite Chinese takeaway.
                  • tiking
                    • Jul 2006
                    • 1691
                    #24
                    Very nice indeed. Seen this method many times over over a decade. Old school method.
                    • Airborne01
                      • Mar 2021
                      • 3954
                      • Steve
                      • Essex
                      #25
                      Aluminium Coke tins also work well, but I use a roller type device from a craft shop.
                        • 18266
                        I found the aluminium foil baking trays perfect for the job.
